Clem Engine was the real deal, I now know how it works and can prove it!
Started by TommeyLReed, September 18, 2015, 07:46:37 PM
TommeyLReed
CENTRIFUGAL FORCE
The centrifugal pump works in the same way as sucking on the straw. As the engine starts, the impeller turns which forces the water around it out of the pump's discharge port. The partial vacuum created, allows the earth's air pressure to force water up the suction hose (straw), and into the suction (inlet) side of the pump to replace the displaced water. When the water hits the rotating impeller, energy of the impeller is transferred to the water, forcing the water out (centrifugal force). The water is displaced outward, and more water can now enter the suction side of the pump to replace the displaced water.
TommeyLReed
This is a very good video to explain the vacuum of water due to centrifugal forces.
http://www.thenakedscientists.com/HTML/experiments/exp/pumping-straw-a-centrifugal-pump/
Equation for centrifugal  force The equation for the outward or centrifugal force due to inertia of an object following a curved path  is:
F = mv2/R
where
F is the centrifugal force pulling object away from center
m is the mass of the object
v is the straight line velocity of the object
R is the radius of curvature cause by the centripetal force
This equation is similar to that of the centripetal force  causing an object to follow a curved path.
https://www.youtube.com/watch?v=Zip9ft1PgV0
TommeyLReed
Hi All,
Most engineer think in a very small box due to the rules they are told not to go out of.
They are discredit by their peers if they go beyond these rules and kicked out of their group for good.
I do back up my work with mathematics, but this one does not have enough data to prove or disprove it.
Too many variables at work, that's why I believe I must build it to verify not if Richard Clem build this engine, but to see if it is over unity.
"Those that believe in the big bang theory, have already claim over unity , where did this energy come from?"
Tom
TommeyLReed
Not really the answer to the fact that in a centrifugal pump of water from the center and flows outward due to inertia in all direction.
Like a flywheel spinning where the inertia is greater then the atom holding it together and explodes apart. This is another energy that is greater then the mechanical load spinning it.
Tom
