Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
cradu
Hello All,
Please, could you tell me if, at the end of the day, is the invention of Mr Chas Campbell working with real as OU system ?
Did somebody succeed to make it to work ?
Kind Regards,
Chris
Pirate88179
Jeg
Hi Guys
I have replicated Campell's idea, but i have some problems when i feed the output to the input. It seems to me that a basic synchronization is needed between the 50Hz output of gen and 50Hz input of motor. Do you think if by adding a cap will fix the phase difference? Is there any other mechanism that is needed for bringing the two signals in phase? After plugging it again and again, at the end i saw some little smokes going out of my generator's socket. Any ideas?
Paul-R
I would have thought that the frequency of the output would depend on the rotational speed.
Can you not function only in DC ?
memoryman
Since the final pulley ratio is 2.2:1, having 3 sets of pulley is unnecessary; drive the flywheel directly with the motor and make the  only pulley set 2.2;1. Better yet, use a generator designed for 1430 rpm.
As Paul-R says, use DC only but make sure that the voltages match at the design rpm.
Best is not to spend time time/money on this at all.
