The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
0 Members and 16 Guests are viewing this topic.
wattsup
@all
OK here's a photo of the secondary after alu-varnish. Now I'll let it dry for 2 days and maybe apply another coat.
@Brnbrade
Just one question.
Does the second layer of alu-foil cover the primary completly?
wattsup
Well, as this build continues here are some more photos.
Photo #1 is a shot of the 2nd alu foil rolled.
Photo #2 is a close-up
Photo #3 is a shot of the alu foil cut on each end.
Photo #4 is a close-up
Photo #5 is a close-up of both rods after alu-varnishing
So we leave this dry for a few days and start the primary wind.
Almost done.
Mike Furness
As I have just been directed  here from another group, there's much more unknown than known!  I am also an electronics engineer, and a transformer designer!
Many things shout LOUDLY about this design!
Turns ratio, wire guage, even what sort of wire?
Am I to assume that it's standard shellac or solderease winding wire in copper?  insulation in this is 2,000 volts continuous rated! so, why add more?
Aluminium Tube?????
What frequency do you expect it to work at?  Your Iron nails will have huge losses at only a few hundred cycles, and the aluminium tube, even less!
IF this WORKS, and I hope it does, then the dimensions of ALL, and Tube wall thickness will be absolutely critical!   By conventional theory, this has no chance whatsoever of working!
Screening of wires is usually done for ferrite cores, 50KHZ plus, with substantial power throughput, (hundreds of watts)
I would like to end this post, relating to something on a similar (rotating) line that I was SOLD by a man we all now consider a charlatan, there are about the same number of variables in this design, as mine, (approx.11)  and that means that the number of different ways to wind, wire guage, core, and aluminium tubing, and frequency, is factorial 11,(more than the lottery chances in UK of 17 million to one) After a month, I gave up on my device; Moral to this story is that nothing will be reproduceable, except by pure chance, unless EXACT materials, engineering drawings, and tolerances are published.
Mike.
mike. J. Furness
wattsup
@MikeFurness
First of all thanks for your comments and please don't be a stranger. Some guys here on this thread would need your input on some coil designs, etc. I'm curious about the test you have done and on which device. Who's the chartlitan?
I understand and agree with you completely in terms of the many variables. That is why I put up my build specs as clearly as possible.
But the original guy that put up his design called "Brnbrade" has not given any more precise specs on his build. Needles to say I and others have asked him many times for some precisions but no go.
So my third build is using alu-varnish instead of electrical tape as in my two previous builds.
I am about to wind my primary since the aluminium varnish is now very solid.
We'll see. 3 down and 16,999,996 to go.
If every you come back, try and take a look at the ECD thread and how that device has three coils on a mobius. If there anything you can point out in terms of best voltages, frequencies, etc. I am thinking of pulsing 100K vdc at milliamperes.
Here is my ECD build spec but you may need to read some of the thread to get an idea.
http://www.overunity.com/index.php/topic,2535.msg37956.html#msg37956
Lastly, if you are knowledgable in transformers, maybe start your own thread and talk about transformers and their applications in "potential" overunity devices. Traps to avoid. Also, how you see back emf and how it can be controlled or captured for re-use. We need all the help we can get here.
Kind regards,
wattsup
wattsup
@All
OK, here it is, the CBC-V2.0. I will eventually put up the revised build spec on this one.
I finally decided to keep the whole thing untapped. This way I can try different primary coil lengths by just rolling them on a separate rod and then simply slipping them onto the core.
The present Primary has 35 turns. The secondaries in this picture are connected in the cross mode.
Thus far, nothing special to report. Same old same old.
I am still looking for ceramic caps that have low voltage, high mf but have not succeeded to find them yet.
Will be trying all the trial configurations #1 to #5 to see if anything gives.
This is a pretty long build in itself plus my lack of time by doing so many other things, plus the obvious lack of any type of response by Brnbrade sort of put this project on the low end of my priority list.
Anyways, I will see with time if there is anything to this or if Brnbrade was just pulling our leg by simply adjusting his meter calibration set screw to a higher level when he took his pictures.
You know what, nothing would f*&kin surprise me anymore. It seems like ever Joe Blow that comes on the forum with something new to show always has some strings attached. No one is transparent. They always have something to hide or some f&?ckin idiosyncrasies that hold them back from talking openly.
Sorry about the rant but I am so tired of all this bullshit. Seems like the only real teamwork happening here is when everybody goes out to lunch.
