LENR and phluorescent tubes
Started by franco malgarini, February 02, 2016, 08:37:36 AM
franco malgarini
conradelektro
Quote from: franco malgarini on February 02, 2016, 10:18:23 AM
It ''s all about power ...
@franco malgarini:
I looked at the theory of LENR in fluorescent tubes. As far as I understand, the Low Energy Nuclear Reaction (transmutation) happens very rarely in the fluorescent tube during normal operation. So, one does not have to do anything special (just light the tube in the normal way e.g. with 220 V AC) and the LENR is happening very very rare.
Therefore I do not understand the reasoning behind your drawing. The generated heat in the tube will be more than negligible (practically zero) and the coil around the tube (around the water tube, not even around the fluorescent tube) does not have any function, unless you hope to increase the LENR in the gas of the fluorescent tube by that coil? And if you want to heat water with a coil (induction heating) one can omit the fluorescent tube in the middle.
It is very hard to see a reasonable argument behind your drawing? What should cause the miracle LENR in an apparatus according to your drawing?
Greetings, Conrad
franco malgarini
We make accelerating the lenr reaction (electron+proton=neutron).
The problem is the power of tube: HT, 220 volts,ballast or other....
