Sharing ideas on how to make a more efficent motor using Flyback (MODERATED)
Started by gotoluc, November 10, 2015, 07:11:57 PM
gotoluc
Quote from: billbailey on February 09, 2016, 08:01:01 PM
what an ingenious fix and with hand tools yet.i would have needed a rotary table to make that piece.great video's and research.
Hi Bill,
Nice to see you have joined the forum.
Thanks for your comment
Luc
Quote from: Over Goat on February 18, 2016, 09:49:24 AM
Luc has gone dark on this, I wonder if the final results are so good he doesn't know what to do now  :)
what if he's just blown away with his numbers, he's been advised to keep a lid on this for now
I'm still around, just been busy with a few things.
May have an update tomorrow.
Luc
gotoluc
Here is a video update.
Motor is now working perfectly. So now the load tests can begin so we can establish the (modified) motors efficiency. Then I will add the assist motor which will only be powered by the primary motors flyback and see if it helps boost the efficiency which is the main goal of this research.
Link to new video demo: https://www.youtube.com/watch?v=aXtkUfdlvRI
Thanks for your interest
Luc
gyulasun
Hi Luc,
Very good progress indeed, thanks for showing it. I would suggest one thing if you agree in connection with the load tests. You showed the 128 mA current draw from the 24.7 V input voltage for one of the 3 phases and showed also this current increased a little (to 132 mA or so) when you mechanically loaded the shaft.
What I would suggest is to make an adjustable and dependable mechanical load for the shaft, better than your fingers and set a given load on the shaft and logging the loaded rpm and current draw and THEN compare these data to the ones obtained with the assist motor also working. I guess your fingers and ears are 'calibrated' to a certain degree by your excellent experience but perhaps a better brake on the shaft with repeatable "grip" force would be better.   ;)
Thanks,  Gyula
gotoluc
Quote from: gyulasun on February 23, 2016, 03:46:42 PM
Hi Luc,
Thanks,  Gyula
Thanks for your post Gyula
You're right, the finger load test does not prove much but now that the motor is operating to my liking the next step is real load tests.
Stay tuned
Luc
gotoluc
Here is a quick video of the first load test using a RC motor as an AC alternator which is directly attached to the motor shaft.
I'm a bit at a lost :-\ as to how I can calculate the motor efficiency if there is no change to the input power when the alternator is put under load.
Link to video: https://www.youtube.com/watch?v=Xsgk6CRfMus
If someone can suggest how this can be done that would be helpful.
Luc
