Joule Thief 101
Started by resonanceman, November 22, 2009, 10:18:06 PM
0 Members and 59 Guests are viewing this topic.
tinman
 author=minnie link=topic=8341.msg479726#msg479726 date=1460027031]
QuoteOnce the current is flowing at a steady rate, it "costs" nothing more to maintain the magnetic field, and the field itself doesn't dissipate power.
The cost of maintaining the magnetic field,is the flow of current through the coil--no current flow,no magnetic field.
So we have a steady flow of current,and that gives rise to a stable magnetic field--nothing is changing,nor needs to change in order to maintain the magnetic field. But if we have a stable magnetic field around a coil,that dose not create a steady current flow. Current needs no change in time to create the magnetic field,but the magnetic field needs to change in time to create current--or dose it?.
We could also say that the hot air in a balloon creates lift,but lift dose not create hot air :D
QuoteThis is how superconducting magnets work.
Superconducting magnets also require outside energy to exist,and this outside energy is in the form of super cooling the conductor. As the conductor draws in energy from the environment(heat),then it slowly looses it's superconductivity.
So energy was needed to create the superconductive state,as energy is needed to create a steady magnetic field around a coil.
No one has been able to prove that the magnetic field takes no energy to maintain,as you cannot have a current flow through a conductor without an associated magnetic field.
QuoteThe situation is perfectly symmetrical. You get no current produced from a stationary magnet sitting next to a coil, because there is nothing changing.
The same could be said for the current flowing through the coil-as stated above. What is changing in time within that coil that gives rise to a stable magnetic field?.
A magnetic field changing in time is not what creates current flow. Current flow is created by the motion of the Electrons, Ions,or photons. We can prove this by looking at the simple homopolar generator,where current flows due to motion of the electrons in the conductor,as the magnetic field dose not change in time in regards to the conductor. If the conductor has no motion,then there is no current flow. We also know that reversing the direction of motion,also reverses the direction of current flow. We can have the magnets fixed to the conductor,so as they rotate with the conductor,or have them fixed to the carrier(frame),so as they do not move with the conductor,and nothing changes.
If the flow of current is needed to create a magnetic field around a coil,then current must be flowing within a permanent magnet. Energy is dissipated by the electromagnet's coil due to this current flow,and so energy must be dissipated by the permanent magnet.
Most just say--well the magnetic domains are now aligned,and so we have a PM. But hardly no one ask's- what is the energy that is maintaining that alignment-what is actually going on with each electron within the atoms of that magnetic material ?.
The biggest problem here ,is that most have just settled for the good old !Faradays law of induction-a theory pieced together as the result of confusion--why one,and not the other?
Well,as they dont yet know what the magnetic force is,then Faraday's law of induction will do for the time being--as we have no other answer.
This is what people have settled on. We now know how to create and use the magnetic field,so why bother finding out what it actually is? :D
QuoteMove the magnet (or the coil), so that the coil experiences a changing magnetic field, and you get current.  Remember Faraday's Law of Induction (and pay no attention to the confused ravings of EMJunkie):
Like i stated above-neither the magnetic field or the conductor have to move in relation to each other for there to be current flow-there only has to be motion and a fixed reference point,but the magnetic field and the conductor may travel together where there is no change in time between the two-the homopolar generator ;)
The holy grail is finding out what the magnetic force is--what is that magnetic field?.
The very same happened when we figured out what light was-like sun light. We then learned how to use these photons to knock electrons out of the park,and create a current flow-the solar panel.
Now,can you imagine what will happen when we find out what is flowing in this field that surrounds a permanent magnet,and then we find our magnetic field !solar panel!.
We know there is a magnetic force-we use it all the time.
We also know that force is -Quote: strength or energy as an attribute of physical action or movement.
So something is in motion in the magnetic field of the permanent magnet--we just have to work out what it is.
Brad
ramset
As an addendum to post 1517 on resonance in an ICE being mostly a negative issue
Johan has posted this before regarding the Resonant secrets of 2 stroke normally aspirated engines
  in 1961 the resonant 2 stroke secrets were taken from the German team in motorcycle racing and traded to Japan's Suzuki for freedom
[from behind the iron curtain]
prior to that time the 200 HP per liter barrier for normally aspirated engines had not yet been reached .
todays 2 stroke normally aspirated resonant engine builders are over 1HP for every 2CC's of displacement ..
and climbing.
the power band on 2 strokes has been small ...but there is something very special that goes on when you create a HUGE
STANDING WAVE
between the tip of the inlet and out the back of the exhaust [yes the wave reaches past the exhaust]
Johan Quote
A high Tuned 2-stroke, is Resonant in every single Cavity, and on the 'Power-band' or 'On the Pipe' it Resonate's between the serie fluide Resonant cavity's, this last also like I described in my first explanation.
The Reed / I-disc, is a Fet, the Crankshaft case and Cylinder is a ................ ?
Why is a 4-stroke far over 100 degrees Celsius, and a optimum 2-stroke only 55-60 degrees Celsius with a exhaust over 250 degrees Celsius?
end quote
this Huge standing Wave has an effect which defies change in some way ,I have heard others refer to things happening in the circuit which don't make sense once the wave manifests
like self tuning and maintaining the standing wave regardless of input or output [or load]
member Chesnyt mentioned this recently in his water cell discovery and another builder has alluded to this "anomaly"
in his unique electric motor builds .. for years now.
there is only one way to maintain a standing wave.
resonance
@Miles when it comes to "all things resonant"
never assume you know it all....
or insult others due to your own ignorance on the topic!
you have a Propensity towards this and assume all to often "You Know it all" and correct and embarrass others when you should not .
Thanks Grandma
Chet:
QuoteMiles when it comes to "all things resonant"
Don't put words in my mouth that I never said.
Put up a mechanical schematic and timing diagram and explain the "huge standing wave" because without it it appears to just be talk.  I am willing to learn but with just talk it could just be your resonance fetish bias rendering you all dreamy eyed.
ramset
Miles
AS Johan has said
The breast is no longer available to you .....
Thanks Grandma
Brad:
QuoteIf the flow of current is needed to create a magnetic field around a coil,then current must be flowing within a permanent magnet. Energy is dissipated by the electromagnet's coil due to this current flow,and so energy must be dissipated by the permanent magnet.
You are just proudly demonstrating your ignorance and willingness to invent your own Bizarro logic.  Energy is not being dissipated by a permanent magnet.  But don't let that fact stop you.  You are the infallible Dr. Brainfry and what Brainfry says goes.
