Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
Gheller J
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã, Ã,  WFCÃ, Ã,  WHITEÃ,  POWDERYÃ,  COATÃ,  FROMÃ,  CONDITIONING
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  http://www.youtube.com/watch?v=Rx2uEsbTt8Y
Aaron says its Calcium Oxide
>>>>>some ppl are tryin 2 use RO and distilled water for conditionin
>>>>>you don have calcium mineral in them
>>>>>so jus use TAP water ONLY or collect water from free flowing streams could work better than tap water!!!
Gh. J.
dutchy1966
Quote from: Gheller J on September 07, 2007, 04:54:36 AM
                         WFC   WHITE  POWDERY  COAT  FROM  CONDITIONING
Gh. J.
Seems logical to add EXTRA calcium to the water to speed up the layer forming. You can just buy it at the the pet shop. Used to add to RO water for fishtanks...
Robert
Gheller J
dutchy>>>>
Calcium Oxide coat is Aarons presumption/deduction and he says it cud be anythin!
>>>>>> It hasnt been analysed!
There r a lot of mineral salts present in natural water
>>>>>> could b any oxide or hydride or an exotic combination composition!
>>>>>> Also 2 note dat Aaron has conditioned at 10V 2 Amps for 2 hours straight n stops for an hour and not like d conditioning process which Ravi mentioned!
>>>>>>therz a possibility dat with the increasin Amp process mentioned by RaviÃ,  Ã,  there are diff kinda mineral / deposits layers formed on inner tube surface!
>>>>>> donno if Aaron used pulsed 10V 2Amp DC or straight>>>>>>>Ravi's was pulsed!
>>>>>> so jus b careful which process u follow!
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã, Ã,  its not jus a layer dat you need 2 create but d RIGHT kinda layer!
This cud b proven if it works or not by Aaron himself if he checks for d difference in gas output>>>>before n after the conditionin!
Gh. J
Gheller J
SUCCESSFULÃ,  CONDITIONINGÃ,  NEWS!!!!!!
WFC Conditioning does reduce Amp draw with the same gas generation!!
So guys just build dis n you'll know it works!!Ã,  U have a replicated proof now!
Message:
There is increase in production for same input. Actually, I will post msg about it. The amps reduce over couple hours by couple hundred ma's meaning that there is more restriction and gas "appears" to be identical. Didn't measure gas but with amps reducing with dial on variac same...same production for less.
Aaron
Gh. J.
Gheller J
No Posts at all?????????????? ???
Cmon ppl has any1 got any tubes conditioned?? :-\
Gh. J.
