New April 2016 Video from Kapanadze shows again KWatts of Free Energy
Started by hartiberlin, April 01, 2016, 06:06:31 PM
cheappower2012
Its assumed that everybody that goes to a demo of Tariel is a fool.
If you assume this you live in a dream world where only you know anything.
There has never been any person saying Tariels stuff is fake other that skeptics saying he could have
done things to fake it.The complain is he cheated me ,didn't give anything,how many
other demos has he done that were not recorded.Hes done this over a long period of time
yet no one has ever come forward and said I have proof that its fake.
he should have had all the appliances unplugged, also the light,he should have had a short connection
from the box to the plug in receptacle.He should have moved every appliance from near the wall
and plugged them in one at a time.He should have shown an oscilloscope picture of the ac output
if its a modified output its locally generated,if a sine wave a possible hidden wire.
People forget the real purpose of Tariels demo's is to lure in an investor,using hes greed against him
make them  believe that there going to go in business with Tariel in making these devices,remember the aquarium 2 team.
Tariels purpose is get the money for a demo then tell the investor to fuck off,and move to
the next victim and give them nothing.Is the device real,it depends on whither you believe a glass of water is half full or half empty.
If its real it can not work on principles taught in college,this is why the giant
brains that lost the ability to wear hats have no advantage,they tend to see the
trees not the forest.There is no way that this device device turns on with a 9v heavy battery
if you look at a past video,it takes a lot of current at 220v to start the device.
I would guess there's a big 12v battery hidden activated by a relay,the relay activates by 9v battery.Once the device starts its in a looped
mode,it doesn't need the 12v battery or the relay.I have done 2 hardware simulations,one electronic the other electro-mechanical
as long as you supply energy they will loop,this allows one to understand the behavior,since the difference is one you supply energy the other is energy by supplied by the device.
All of Tariels devices appear to be 50HZ,220vac,there is far too much Tesla hero-worship going on.
forest
C'mon man. He had many years to master this device. It is just a matter of frequency and voltage step up to run it from 12V car battery or 9V 200mAh small battery in full closed loop. It probably require just to charge the buffer capacitor enough.
Hoppy
Quote from: a.king21 on April 22, 2016, 02:52:14 AM
Arto: did you know that Kapanadze has 2 patent applications?
Did you know he outlines the principle?
You should read the patents before  you make foolish comments.
All you are doing is misleading people.
Who do you work for??
Unless Kapanadze is prepared to video a demonstration that at least shows all device peripheries moved from their initial positions and earth wires disconnected for close-up inspection, then he is simply inviting justified criticism and suspicion. Any comments about the modus-operandi of the device are justified in this situation, irrespective of what patents show.
Zeitmaschine
He has done so already. He has all device peripheries moved from their initial positions and earth wires disconnected for close-up inspection in the green box video. Just remaining the far-fetched possibility that the earth wire is secretly stitched together of two different types of wires (none of the spectators became aware of) in order to connect a hidden hot wire.
Here (for the records) the two TK patents which so far the brightest minds cannot comprehend:
WO2008103129A1
WO2008103130A1
Maybe knowing that the Stepanov device uses a frequency doubler circuit (see illustration below) helps to understand part of the TK patents. And I don't think that the stuff under Stepanov's cardboard box is some sort of a decoy only. Because it's hidden in a way that it took me two years to figure out the function of those diodes, capacitors and that (barely visible) resistor.
