yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
verpies
Quote from: poynt99 on May 14, 2016, 12:59:38 PM
There is no paradox, and verpies is wrong because the inductor does not represent a short the moment it is connected to something, even an ideal voltage source.
Indeed I would be wrong if I wrote this about an inductor connected to a voltage source as in Fig.2 , but I was writing about the circuit stipulated by Tinman, which is the circuit depicted in Fig.3.
The latter circuit is equivalent to the diametrically connected toroidal inductor that MH invented as an example and was analyzing in collaboration with me.
verpies
Quote from: MileHigh on May 14, 2016, 01:17:12 PM
Verpies:  I suggest that you step it down a notch and add some more description at times so your message is more readily understood by both the "ordinaries" and the "gurus."
I don't do it deliberately.
I even consider it my failing if I am not understood.
I need detailed feedback so I can adjust my wording.  Without it I am blind to such problems.
poynt99
Quote from: Magluvin on May 14, 2016, 02:32:59 PM
See, something MH said bothered me a bit. He said that a resistance of .000001ohm,  1uohm was virtually seemless to being an ideal inductor. Would you agree with that statement? Not trying to pit you against him. But it would be nice if that statement were to be considered true by you or not and give us your understanding as to why your answer is what it is.
You can not really go by the absolute resistance alone to intuit if that will make the inductor act close to "ideal" or not. It really comes down to the ratio of the inductance to resistance, i.e. tau.
Yes, I would agree that 1u Ohm with 5H is sufficient to get good results when compared to an ideal inductor.
Let's explore if tau could be a good indicator of what inductance to resistance ratio is acceptable as an "ideal" inductor for our particular application. So let's look at MH's example, and use 1u Ohm as the inductor's series resistance: 5H/1u = 5Ms. That's a little less than 3/4 of a year. That is a ratio of 5M. Maybe this is excessive? We can also do some tests to see what might be reasonable: With R=10m Ohm, the end current after 3s is 2.389A, which is pretty close to 2.4. The L/R ratio for this case is 500. So we could establish this as a minimum ratio to achieve near-ideal results. If your L/R ratio is 500 or greater, you will achieve very close to ideal results.
Another example: if your inductance is 100mH, then you can have a maximum of 200u Ohm before it won't be so close to ideal when using the previous ratio of 500:1.
For interest sake, let's see how far we would be off with a ratio of 100:1. So with L=5H, that would be 50m Ohm. That gives us an average current of 2.34A, so the error is 2.5% or so? What is your desired tolerance? If 5% is acceptable, then perhaps we could go to a ratio of 50:1. Let's see: L=5H, R=100m Ohm. This gives us an average current of 2.28A, which is about a 2.28, exactly 5% error. If that is close enough, then we need only ensure a 50:1 L/R ratio to get results within 5% of ideal.
poynt99
Quote from: verpies on May 14, 2016, 07:45:42 PM
Figure 3 is essentially nonsense, and does not aid in the understanding of the problem at hand.
verpies
Quote from: Magluvin on May 14, 2016, 02:08:26 PM
I agree with you on the no current flow at t/0 of an ideal inductor.
So do I and I even came to the same conclusion in a step-by-step analysis of a resistive inductor here.
If resistance is zero, and no losses, then that underlying ideal inductor mechanism should be lossless and 100% efficient also. And if that mechanism is lossless then the the inductor should continuously impede an emf presented at the input. ;)
That's a reasonable thinking but note that constant and continuous impediment does not mean complete impediment.  The lack of complete impediment means that the current is not frozen and can increase with time.
That's why when an ideal voltage source is suddenly inserted into an ideal but finite deenergized inductor (as in Fig.2), the current through the inductor increases linearly from zero to infinite current in infinite time - not instantaneously.
PW says that a straight wire has inductance, and I agree, no matter how tiny the inductance is.
I agree with that too.
So it may be that the ideal straight wire may not be able to pass current if the inductance mechanism is 100% efficient.
but when this wire shares the inductor's flux and when the coupling coefficient (k) approaches unity, then this wire, and its inductance, becomes a part of the inductor and closes/completes it losslessly.
