THE INFINITE ARRAY ENERGY GENERATOR PART II
Started by lancaIV, September 02, 2016, 08:05:19 AM
FatBird,
on the left side from the epo.org/espacenet page you see the different documents in e-paper format
or as "original document" e-copy.
Enter (in the original page) and look for the wished information:
Bibliographic Data
Description
Claims
Mosaics/Images
Original document
FatBird
I did that, but I don't see how that is relevant to what's being discussed here.
Hmmmmmmm.
Clearly,it is ! And makes part from a global program !
https://translate.google.de/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2F2000-Watt-Gesellschaft&edit-text=
At first    : definition of the average sustainable -per capita- consume !
                         Future Order:   Rationalism ;)   over-consume limiting
                 defining priority : Wattpeak limit
Seconds : the energy/power/natural source !
                 renewable fuel sources(gas,liquid,solid)
                 DC,pulsed DC,AC electricity;Volt-grid ?
society consume standart ( per capita eco-budget)
How many sqm/cbm living area per capita ?
Average ambiental in-house temperature ?
How many litre water consume ?
How many KWh-energy consume per capita per day ?
Kitchen-/bath appliances energy consume reduction !
TARGET : optimizing the energy Wp and KWh consume to such a level,that only more a 1KW-FE-
generator will be the autonomous household power source !
repeat:
Federation of American Scientists :
http://fas.org/programs/energy/btech/advanced%20technologies/Affordable,%20Safe%20Housing%20based%20on%20EPS.pdf
32-38 sqm Starter Family House                  72-78 sqm Expanded Family House
        ~ less than 60 sqm morphing foldable portable building
http://rexresearch.com/cuinanoagwire/cuinanoag.html
Super-insulated clothing could eliminate need for indoor heating
From the above view I would have to agree, "eliminate need for indoor heating" system
So no more 600 W per household,but 12 Wattp per capita body heating energy will be the standart !
Fat is ugly,fat=oversized consume,too !
Low consume society ! No credit ! Cash or barter finance system !
automobile industry change :
In Europe the max.traffic velocity in the cities will become 30 Km/h= 1 KW electric motor sufficient
or bicycle pedalling
                                                        The FE-generator dimension ?
                          Kitchen/bath appliances consume ? Living area heating/cooling ?
f.e.: http://www.micromedia.li/microhouse/index.php  = moveable pantry-kitchen
http://www.geolitesystems.com/conv.html : housemaker http://www.geolitesystems.com/flpln.html
Duche : http://www.inpama.com/index.php?content=invention&id=816 water and energy saving
365 days water collection,electricity-free : solar condensation and fog/rain collector
and (no /low e) recycling: http://www.aqsolutions.org
black water : compostingtoilett like in this modern cabin used
http://www.treehugger.com/modular-design/habitaflex-folding-homes.html#14730694289391&action=collapse_widget&id=0&data=
Electric appliances consume list :
https://translate.google.de/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.oeko-energie.de%2Fprodukte%2Fsolarstrom-photovoltaik%2Fsparsame-dc-verbraucher%2Findex.php&edit-text=
with better efficiency motors and heat elements                                               1500 Wh/ 24h
included syn-gas-owen(toaster,hot water kettel)
refrigerator:
http://mtbest.net/freezer-to-fridge-thermostat.html                                           100 Wh/24h
Light:
http://www.osmatech.net/led.html        100Wh/24h
                      Making  the 200 Watt compact generator sufficient for the urban eco-household !
                        With storage battery=puffer.(=conventional ,approved technology : 5000 cycles charger )
                    ( urban citizen households can begin to reduce their consume to this 200 W per hour on-grid delivery maximum)
    200 Watt x 12 h x 0,80(battery input and output conversion losts) x 0,85(charger losts):
                      DC output/DC consumer (or AC inverter x 0,85) : 250 Ah battery-set
+  200 Watt x 12 h direct energy conversion to consumer  (heat,cool,movement,light)
You have fat livingpartners ,a healthy solution,"social movement" :
https://www.google.pt/search?q=bicycle+generator&client=opera&hs=dYY&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjQsb2o_vfOAhVFOMAKHf3-AXQQsAQIIw&biw=1366&bih=668
but let them do this outdoor
a commercial mobile chalet with up to1 week autonomous living range :
http://www.mobilchalet.de
Infrastructural independence
All required energies, light and warmth are won from sun radiation. With the roof area sufficient drinking water can be won. Efficient house technology safe to operate makes drinking water, hot-water, heating and electricity in a sufficient quantity available for convenient use. A hot-water solar collector as well as a Photovoltaik collector are core of the plant for the electricity generation. For electricity storage a heat accumulator and a greater accumulator capacity is installed. Several days can therefore be bridged without solar radiation.
An alternative to this " (natural electromagnetic) sun radiation" will become the solution for
autonomous grid-independant living.
And/or "electro-magnetic radiation" will become part of the energy conversion system:
http://solarwindow.com/technology/
http://www.greenoptimistic.com/green-ferrite-solar-cell-japan-20110920/#.V8253lpX9aY
There is not the need to re-invent the wheel, only a well sized electric generator
and developing from the fundamentals : https://www.jovoto.com/projects/300house/ideas/12735
                                                    A house must provide shelter from the elements and physical harms
        Yes !
        versus:
https://www.google.pt/search?q=chu+200&client=opera&hs=Qhv&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjK2oziofjOAhXKLsAKHbkRDI0QsAQIIw&biw=1366&bih=668
        Good idea,bad price result !
        Re-engineering simple life !
                                                              http://www.n55.dk/MANUALS/Manuals.html
The searched FE-generator dimension : between 200W up to 1000W(=less battery capacity need) output permanent
        C.O.P. ?
                      static = electro-magnetic DC force amplifying/au(g)menting process by revolving the electro-magnetic lines
                             (and getting the fire-stone against fire-stone=pyrit effect: pyro/flash/burst/signal/pulse/ignition)
Figuera/Buforn static electro-magnetic power amplifier   (generator) original and modificated
https://books.google.pt/books?id=KhUWDAAAQBAJ&pg=PA23&lpg=PA23&dq=figuera+buforn&source=bl&ots=rGYZDkMLRm&sig=WoKiQRSC1IevC84s9GZ1WUxt6pU&hl=de&sa=X&ved=0ahUKEwjD4ITipPjOAhWbF8AKHcXjBP0Q6AEITDAF#v=onepage&q=figuera%20buforn&f=false
Henri Trilles static power amplifier
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=FR&NR=2695768A3&KC=A3&FT=D&ND=3&date=19940318&DB=EPODOC&locale=en_EP
Rafael Martinez Gutierrez static power amplifier (generator)
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=ES&NR=395792A1&KC=A1&FT=D&ND=3&date=19721116&DB=EPODOC&locale=en_EP
Keiichiro Asaoka static dynamo
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=21&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990720&CC=US&NR=5926083A&KC=A
and
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=30&ND=3&adjacent=true&locale=en_EP&FT=D&date=20030110&CC=JP&NR=2003009558A&KC=A
Paul Lucien Galey static electrical power generator
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=8&ND=3&adjacent=true&locale=en_EP&FT=D&date=19761217&CC=FR&NR=2312135A1&KC=A1
Which input electricity kind ? Which amplifier/generator output kind ,Voltage Amperage Frequency ?
Consumer : DC ? AC (HV ?)? Pure sinewave (50/60/ HF ?) ? Converter/Inverter needs ? Rectifier ?
The input energy battery source and consumer energy buffer :
250 Ah x 12 V + charger + inverter + recharge process to DC rectifier
