GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
citfta
I know for a fact he has tried there.  I doubt if there is a forum anywhere he hasn't tried.  Of course most of them kicked him out shortly after he got there or didn't even let him join in the first place.
that_prophet
   If you use the DC motor to generate a single rotation of a 100 cm circumference pulley, giving you 100 cm of moving belt, which you run by ten 1 cm circumference pulleys, with AC generators attached, this would give you a total of 10 X 100 =1000 cycles of AC electricity. That is one rotation of a DC motor in, through pulley mechanics producing 1000 cycles of AC electricity output. Now, try and tell me that these 1000 cycles of AC electricity cannot produce enough DC current to rotate the motor once.
Quote from: pomodoro on March 08, 2017, 12:31:30 AM
Have you tried energetic forum phat profet?  You may get more belief over there. I believe there is a priest of two floating around over there.
pomodoro
Quote from: that_prophet on March 09, 2017, 04:51:11 AM
Actually they don't. There you go, I tried. So how many days left exactly ...700 or so I believe.
citfta
Quote from: pomodoro on March 09, 2017, 05:28:11 AM
Well actually they do produce enough electricity to turn the motor.  IF the motor was not connected to the load.  What he has been told a thousand times and still doesn't understand is that with all those generators or alternators whatever he wants to call them connected to the large diameter the mechanical load will be so large the motor will stop no matter how much power is applied to the motor.  He refuses to understand the basic mechanical problem with his design.  He just does not understand that it takes real power to turn a generator when it is loaded.  He claims to be a genius but is unable to look up the simple basics of how a generator works.  He also doesn't understand how a motor works because he keeps referring to a spark of electricity to run his motor.  His very deep lack of knowledge has given him this delusion of an idea to produce electricity for free.
ramset
So his name is Joe ??
@ Joe ,
Do they Let you talk on the phone there ?[I heard you were recovering from a very serious head trauma ?
I hope your recovery is going well.
I'm sending you a PM.
respectfully
Chet K
Thanks Grandma
