N.R.M.R.E. An investigation.
Started by Grumage, April 11, 2017, 06:43:24 AM
Jimboot
Quote from: TinselKoala on April 26, 2017, 08:53:23 PM
Those scopeshots showing overlapping waveforms are telling you that your signal isn't strictly repeating, but is changing in timing and/or voltage, and the scope is "multiple triggering" on different parts of the unstable waveform.
Geeze my hunch was close, kinda. Thanks
AlienGrey
Have a look at this earlier Nelson Rocha circuit, just try and trace how it could possibly work, in his video it does work or does it ?
if you look at the first relay contacts it's not possible to wire it like that and get it to operate relay 2 and even if you got that to work by hook or by crook it's contacts are only switching the + supply through. It has no -ve supply on the lower section.
If you bought all the bit to build this device there is no way it would work ! you have a go and see how far you get !
AG
AlienGrey
Getting parts of the device to work.
1 neon is a 90volt spark gap arrestor
2 moth relays are in series via a NC relay contact No not used
2 Relay series resistor about 30 R to tune to about 50hz or 60 depending on Iron core
3 scope shots of wave forms around relay coils ect
4 Anyone have any ideas ?
forest
Does somebody maybe downloaded Nelson videos and can share them ? Also I'm pretty sure I saw such circuit in the past from one newspaper. There was a scientist showing one wire transmission of power with broken wire making just a knot on it. I can't recall his name.
