GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
My name is Joe Lynch + I have a pre-school simple way of using pulleys to multiply AC electricity. This can be done by only paying the small amount of DC current, for the single rotation of a DC motor with a 100 cm circumference pulley attached + then you run this 100 cm of moving belt past 10 mini-pulleys of only 1 cm circumference, with free running AC generators attached = you would gain 10 X 100 = 1000 cycles of AC electricity,,, all for the cost of enough electricity to crank over your DC motor once =(a mere spark)
These AC generators would run free of most all torque, as torque is caused when generating power, and power is defined as current multiplied by voltage. Even though you may be winding up massive voltage, (which is useful pressure to crank over your large pulley) you only need to be generating one spark of current, (practically nothing) the minimal amount of current that a DC motor needs to crank over once. So, practically zero current multiplied by even massive voltage still equals practically zero power + torque.
USING PULLEYS TO MULTIPLY AC ELECTRICITY
http://free-energy.yolasite.com/
that_prophet
Please,,, explain to me why these 1000 cycles of free running mini-pulleys cannot generate enough voltage + the one spark of current, to crank over your DC motor one single time,,,
- each half generates what the other half needs
- massive rotations create massive voltage to crank over your DC motor once
- + the cranking over of the 100 cm circumference pulley, through 10 mini-pulleys, easily winds over 1000 rotations of your 10 AC generators
(my health has gotten far worse, my blood pressure is 180/90 all the time. The nurse just took it, + said that it was better, than the 195/90 that it was earlier) + I ask my Father to take me Home to Paradise most every  morning now. This massive pain that I go through daily is getting me down. Sorry, but I no longer wish to fight this battle. I had to change my sheets, as they were soaked, + I must change my t-shirt twice a day now, morning + at night, as the cold sweats soak them
Quote from: that_prophet on April 13, 2017, 03:22:54 PM
Please, re-post the explanation then, OR try explaining it again
as I just cannot see how these 1000 cycles of AC electricity cannot, (with the assistance of full wave bridge rectifiers)
generate enough DC current to be able to rotate this DC motor only the one time
Thanks for posting the pic Dog-One
I think that the pic is needed to better understand how it works
you are using the small amount of electricity to rotate a very large 100 cm circumference pulley
gaining you 100 cm of moving belt, which you run past 10 or more mini-pulleys of 1 cm circumference
if you add 10 free running AC generators, this could multiply your cycles of AC electricity to 1000
+ all for a cost of only turning over your DC motor once
SkyWatcher123
Hi dog-one, Hi prophet, well i was trying to work on something and i was being attacked not much longer after i started to work on it.
There is most definitely a dark artificial force here and i surely didn't create it, it seems to get into people it can around you and then uses them to cause trouble or try to impede good works.
It's too bad really, this could be a great ride, unfortunately there is an infection that needs healing.
If and when, i am able to continue work towards this technology principle, i will do so to the best of my ability, but the road blocks need to be removed from this reality.
peace love light
that_prophet
Free energy is as simple as the pre-school technology of using pulleys + multiplying AC electricity with multiple size and #'s of pulleys = https://free-energy.yolasite.com/ - it is so super simple, that we should be ashamed of allowing satan + his fellow evil spirits, to have kept it hidden for so long = ever since Ezekiel 1:16, where it is first easily described how a UFO motor worked in the Holy Bible, "a wheel in the middle of a wheel". You only have to pay the one spark of DC current to rotate a 100 cm circumference pulley one single time,,,, + through running the 100 cm of moving belt, (which came off the circumference of pulley) + running it by 10 of the mini- 1cm circumference pulleys + attaching AC generators to each pulley, you can multiply your AC electricity to 10X100=1000 cycles of AC electricity,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one small spark of DC current =(just enough to rotate your DC motor one single time)  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
Quote from: SkyWatcher123 on April 16, 2017, 09:58:02 PM
peace love light
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04
http://my2020vision.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://askthatprophet.yolasite.com/
http://possibletimingfortribulation.yolasite.com/
http://aliensandghosts.yolasite.com/
http://hissalvation.yolasite.com/
http://godoflove.yolasite.com/
http://fire-starter.yolasite.com/
http://2020vision.yolasite.com/
http://one-christian-warrior.yolasite.com/
http://2020-vision.yolasite.com/
http://onechristianwarrior.yolasite.com/
http://ultimatejoysticks.yolasite.com/
http://ultimatevideogamecontrols.yolasite.com/
http://thegodofthebible.yolasite.com/
http://incaseofrapture.yolasite.com/
http://rapturequestion.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://whataboutisrael.yolasite.com/
http://myiqchallenge.yolasite.com/
http://evolutiondebate.yolasite.com/
http://biblefilescentral.yolasite.com/
http://whydoweinsultgod.yolasite.com/
http://jesus-christ.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://howlogicchosechrist.yolasite.com/
http://hisonlyword.yolasite.com/
http://whybornagain.yolasite.com/
http://bibleteachings.yolasite.com/
http://doorschristmustpassthrough.yolasite.com/
http://pre-trib-force.blogspot.ca/
that_prophet
Free energy is as simple as the pre-school technology of using pulleys to multiply rotations
+ multiplying AC electricity with multiples of both size and #'s of pulleys
- this is so super simple,
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school  pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
