tinman
Did Russ's fancy scope and power factor correction measurements, calculate the actual current value flowing through R2,and hence,the correct power measurements ?
Can you use conventional power measurements for an unconventional system?
https://www.youtube.com/watch?v=OyG3F_4-TLo
Brad
tinman
Quote from: MileHigh on May 01, 2017, 05:58:17 PM
Oops you can't attach an image to an email so I am posting this here.
MH
Myself and TK have tested your theory,and it seems to make no difference as to where the CVR is placed-be it at the ground end,or the input as you showed.
Further testing is being done,but at this point in time,either way,the OU result still stand's--until we find that !red herring! hiding some where  ???
Brad
tinman
The MH test results.
A 100 ohm resistor on the ground side,and a 100 ohm resistor on the input side.
No difference in current measured.
Yep. And in the full Partzman system that I have been testing, I disconnected all probes and then simply measured the Vdrop across the original resistor with the CH2 probe, stored the trace in the scope as Green reference R1,  and then moved CH2 probe and groundclip to the other "MH location" resistor and measured the Vdrop there. (FG is isolated from ground, so no groundloops are created.)
The Green trace is the stored reference trace from one resistor and the Blue trace is the live trace from the other resistor. They overlap almost perfectly so I moved the Green trace up one division for clarity. There is no difference in input current measured in the two resistors.
Quote from: nelsonrochaa on May 03, 2017, 06:56:45 AM
Seems that you really need go to bench work a bit and make some tests  , and discover by yourself about the questions that you ask , like others do .  Sitting around waiting as someone expects rain is never a good solution.
For sure you will have many things to talk after do some tests about the subject of pancake coil , otherwise like you say you only able hear crickets chirping, because other people are more concerned in working to clarify some of the points of the thread, that call's research  :)
Now if you assume is nothing more to explore on this thread try not be so repetitive about your questions otherwise ,you run the risk of looking a annoying person ask all time the same things .
Why you don't try play a bit with such coils ? even you spend some of your precious time is better than you become annoyed without know in first hand, some of the points that you refute  about any possible advantage of this coils .
I really don't understand such position .  :(
About you say the transformer discussion has pretty much hijacked the real purpose of this thread, i really don't agree with you , because we already change some posts between us about themes like  efficiency of power transfer with this type of coils with a video shot included, but you simple argue and refute saying that a normal transformer  have much advantage in this process of transfer power in relation to a transformer made by bifilar pancake coil , but now you say that a bifilar coil is not a transformer and is only indirectly related   .... this is to i laugh ? what seems to you that ? https://www.youtube.com/watch?v=aEZSCNHDYJs
Is only a coil ?
Do you think people are stupid that not understand what is a transformer and a coil  ? Or you think you are really more cleaver than others  ?
Make something  useful instead of simple create noise, because until now you not add nothing practical and positive to this thread with such behavior.
Do you think you are help anyone at moment ?  To me seems not
Have a nice day
Nelson Rocha
You stop posting crap like this about me.  You can kiss my ass.  I stand by what I am saying and it is true.  Threads get derailed because people chase after one thing and they forget the original purpose of the thread.
Quotewhat seems to you that ? https://www.youtube.com/watch?v=aEZSCNHDYJs
Is only a coil ?
It's a nonsense clip that is just "show and tell" for an air core transformer and indeed it's only a bloody coil.  I told you already that a normal air-core transformer will outperform a bifilar pancake coil transformer and I told you exactly why with valid technical reasons.  So why are you showing that useless clip again?
Do you want to improve your performance in your clips?  I suppose that you are not comfortable to speak English in your clips.  Go ahead and speak in your native language of Portuguese.  If you speak clearly YouTube should be able to convert your speech to text and then translate the text into English in real time.  Also do a write-up underneath your clip that states what you are doing as well as summarizing your data.  You can even do that in Portuguese and then we can copy and paste it into Google Translate if we want to.
Kiss my ass with your "have a nice day" BS.  Your whole posting was useless noise and trash talk about me.  Improve your clips so you actually state something of value and you summarize what you did with data.  The last thing we need from you is another clip that says, "Look mom!  I can make an air-core transformer!"
