Maxim Aliyev replication
Started by justawatt, October 13, 2017, 12:48:40 PM
Jeg
Quote from: captainloz on October 16, 2017, 04:37:06 PM
  Hi, The TT00 is just a little 220V to 12V transformer iron core.  It's supposed to run at 50HZ  It doesn't work in the circuit because the HZ is way too high.
Thanks Captain
Normally at least one of the two long coils as AG said contains a ferrite core so to bring the frequency down. As far as i know, iron cores have to be used in the range of up to about 1KHz if we are to feed them with current. It would be great if you could measure the inductance of your long coils so to take a general idea of what happens inside their cores.
ps. I am sorry too for your money loss mate. I hope that he is not a scam and at the end you will be able to work this device.
Jeg
In addition you can build the device according the drawing and see what frequencies flow inside the contraption at several points. If you are willing to make some tests we are here to help you.
ps. I would start by finding the self resonant frequency of your small iron transformer. Obviously and this is the topic, we are talking about high frequency currents. Only wire length counts.
Forget what i told you about the 1 KHz. It doesn't fit here.
AlienGrey
one thing you must realize on this thread is there are so far 2 different devices with entirely different builds one we have no winding details for and another from the Russian forum that could be replicated if you can understand how to wind L2 assuming it is a winding ?
Regarding the Captains device if I was him I would be trying to down tune the VFO oscillator so the wave peeks coincided with the secondary coil placements on the larger winding stick and seeing what happens to the secondary winding outputs.  Also shouldn't the transformer supplying the volt supply be a 240v - DC converter module or d did your component supply'r expect you to run the Transformer  of the grid ?
Just thought I would add this section on this post HAVE YOU READ IT ??? i REALY THINK YOU SHOULD !!!
i KNOW ITS IN RUSSIAN IF YOU KNOW ANYTHING ABOUT THE Nazi   GLOCKENSPIEL THIS WORKS ON THE SAME PRINCIPLE  8) 8) 8) 8) 8) 8) AND HAS THE SAME INGREDIENTS !!! DON'T SAY i DIN'T WARN YOU !!!
AG
otrok
Hey you guys from the Russian forum. please note in this video. Around the time at 12.40. The pipe is empty as the head of Winnie the Pooh.
https://www.youtube.com/watch?v=xP0emKe_il4&t=684s
AlienGrey
L3/. coil (green color) ferrite (ferrite undergone extensions below) spindle rod 250mm, diameter 20mm winding 770 turns opposing arrows 0.3mm
In the center there must be a hole drilling depth from above 200mm hole diameter 10mm.
At the top, the thread has to be tapered with ferrite. The parameters of mercury are poured into the hole, mercury is smeared with wax and color, and the bolt is attached to the ferrite. The tapered thread does not allow mercury and water to pass through it.
ect ect ect
