Resonance Circuits and Resonance Systems
Started by hartiberlin, March 15, 2016, 03:27:11 PM
Belfior
Hmm if you check the circuit here
http://tinyurl.com/yar2enzh
Why doesn't the current going through collector&emitter stop the voltage on the gate? I thought collector&emitter conducting would stop the base from getting the voltage and then shut off?
If you let your sim run for a while you 'll see that there is a small current flowing
from the capacitor, through the base and out the emitter of the transistor. This
is what is keeping the transistor turned on. I think you need a "pulldown"
resistor or other means to allow the base to go Low and turn the transistor off.
I think.
Also the huge long link has screwed up the forum page, so you need to scroll all the way to the
right to see the response buttons.
Belfior
Quote from: TinselKoala on October 31, 2017, 01:04:48 PM
I think.
Even the mosfet version fails http://tinyurl.com/y9sxb3df
sorry about the link. Using the tinyurl-conversion on the software now
Too complicated and doesn't quite capture the concept.
Try this:
http://tinyurl.com/y7jgmrko
By the way... I can charge a cap to 15 times the supply voltage using only a relay and a diode. Figure this out and you'll catch the concept.
Belfior
Hmm ok so difference to my mosfet circuit was that you have no resistors. Gotta check this out in the real world. Thx!
I wonder if you can do this with the coils resonant freq and if that gives you a boost?
