Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
antimony
Cool its going to be interesting to read the updates.
I have tried to make a small replication, but I havent gotten far with it yet.
Thanks Jack.
Belfior
Quote from: antimony on December 14, 2017, 06:10:17 AM
Thanks Jack.
Yeah I have made like 3 coilcaps now, but I have only driven them with a signal generator. I get an LED to light up with the coilcap, but adding diodes will put that LED out.
Next step is to go higher voltages, but I would expect the "effect" to manifest also on low voltages. Jack is using toroidal ferrite core and I use air core. I am still having doubts if the effect he is seeing is from the ferrite core and not the coilcap.
I also got copper tape for my next coilcap. copper tape + clear scotch tape + copper tape layer 2
Then I got soft copper tubing from fridge cooling system. I will place a thick magnet wire inside that and I got another kind of coilcap to wind on a core
antimony
Quote from: Belfior on December 14, 2017, 07:06:01 AM
I have experienced the same thing. I have only been able to light single Led diodes, but with a small high voltage transformer.
I am using air core too, but I have noticed differences in brightness of the Leds when i adjust with a ferrite rod.
I have always put on insulator Cu tape between the windings so it be comes a sort of hv cap, and i am also able to light leds with the leads of those .
I have thought of using Cu tuning too, but I dont have any at hand right now, but I will try to get some soon.
Do you make a slit in it so it wont be short ed,  or how do you plan on doing?
Belfior
Quote from: antimony on December 14, 2017, 07:48:18 AM
Sorry did not understand :( Make a slit in what?
If you mean the copper tube with the inner wire, the inner wire will just come out of the ends. You don't have to make the 50% offset like in the coilcap document.
AlienGrey
not tried this but can you use one of the zero depletion layer schttky diodes (select one with a very low break over voltage) and of feed it into a jewel thief circuit I have a similar circuit that's been running since last year. (a mos fet in on pos is zero loss and can block the other way  ;D )
