Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
There is a need of collaboration to build it completely.
vikram_gupta11
Hello Sm0ky2 sir,
your and other members guidance is important now.
vikram_gupta11
Dear Webby Sir,
Did you mount the counterweight on the" Flip" side of arm?
As when I mounted both mass on a single side of arm the input was not good but when I mounted the counterweight on the flip side of arm then input was good.
vikram_gupta11
Dear Webby Sir,
The device will work as per your expectation if we use a lock mechanism to hold counterweight after tilting the device.this lock mechanism will work in this way that it will be locked at the time of tilting the device after tilting it from 90 degree( as there is no problem up to 90 degree due to counterweight).
So that the counterweight will be lifted upside due to falling mass when the falling mas hit the upper side of tube.in this way the device will get momentum.
The lock system will be designed in this way that it will be unlocked due to energy falling counterweight as the counterweight will get momentum so as the whole device.
Now your main problem is solved.
As far as I think there will be need of maximum 5 joule energy to this lock mechanism.
vikram_gupta11
Dear Webby Sir,
You are correct that lock doesn't need any energy but I want to tell you that it will work to prevent the falling of counterweight after tilting the device from 90 degree so that the counterweight could move up to provide momentum to the device and decreasing input and increasing leverage.
But you are expert so I think you better than me.
Thank you sir.
