Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
SolarLab
F.Y.I.
Fourier Series transform (Foyer?) - aid using an interactive graphical example,
and why it's important, can be found here:
The free energy of the electron
http://gorchilin.com/articles/energy/pull?lang=en
Study this page; in particular "The energy gain" (formula 1.8)
which is graphically (interactive) shown here:
Simulation of energy extraction with the long line. The increase in efficiency due to the
charge redistribution
&Ph=[1.57,3.14,1.31,1.83,1.05]&lang=en]http://gorchilin.com/calculator/pull?T=0.5&L=0.5&D=0.1&P=0.1&G=[1,0.78,0.6,0.65,0.55]&Ph=[1.57,3.14,1.31,1.83,1.05]&lang=en
Open the Detail box - upper RH - use the US flag for translation; then
adjust the Harmonics - 1...5 and Phases: 0...+180deg; NOTE: Ksub0.2= value
L is 1/4 or 1/2 Lambda of coil (wavelength); The lower graph shows one period of
oscillations, which excite DL (the long line).
After a brief review, it will become clear how and why the proper selection of the
"Harmonics" of a "Pulse" type excitation of waveform on a 1/4 or 1/2 wavelength long line
(e.g. in the form of a Tesla or other high Q coil) might be of advantage (Ksub 0.2);
when also considering the "extraction" timing (green line on excitation signal graph
at the bottom - also shown to the right as a switch and load - yellow when filled.
Move the green line to re-adjust the extraction timing - click along the T axis - reset the cycle.
A study (interactive graph) of the "Pulse" train can be found here:
Calculation of pulse pumping Tesla transformer
[url=http://gorchilin.com/calculator/tesla?lang=en]http://gorchilin.com/calculator/tesla?lang=en
Also - follow the "blue" links. NOTE: A Fourier Series Transform (FT) of a signal (pulse, etc.) will
yield a series of discrete frequencies, including their respective phases in the "frequency
domain;" in turn, Convolving a series of discrete frequencies will yield the waveform
in the "time domain." FT has several forms - for example: DFT (discrete Fourier transform)
ignores the harmonic signal phase information - caution.
One Pulse Example:
http://gorchilin.com/calculator/tesla?Q=200&G=1&b=0.1&fi=400?lang=en
As can be seen - harmonic frequencies and phases matter!
Now you can begin to ENGINEER the (optimum) driving waveform manipulation;
or you might just get lucky - in that case definitely buy a lottery ticket as well, since your chances
of being lucky a subsequent time will have the same odds as your winning the lottery!
For some I'm sure this will come as good news - since upgrading to a new online system, it has become near
impossible to construct a proper post for this board. Therefore, time spent trying to post here will be allotted
to more productive activities. Good luck to everyone and have a great New Year!
FIN
sm0ky2
Thank you Fin
For the purpose of the devices being discussed here, the expanded view
Is overly unnecessary, but good information for people to have.
In order to utilize the higher harmonics (lower sets would be pointless)
we would need significantly more circuitry than what we see.
And if this is to be done, we should first consider the other interferences
in those bandwidths from modern human activity.
sm0ky2
Quote from: jojo500 on January 05, 2018, 07:11:23 AM
one thing on all the devices from tariel , ruslan , akula, barbosa always make me wonder .. most of them use a relativ long cable going from the device to the groundpoint . some of the gys made a big deal about a perfekt ground .. at the same time they lay servral meters of cable in between it .
i did some tests with some intresting results not to long ago .. how ever there is something to look over
all the best
are you thinking some kind of 'EB' effect?
the above Lewin video demonstrates how the earth is an infinite electron source.
(secondary lightning/hv discharges)
and EB experiments have shown that the earth can send charges to other objects
and other parts of the earth.
this effect can be as substantial as we want it to be.
TK once told me to place a coax in the ground and scope it.
all kinds of stuff going on there.
more waveforms than a lot of scopes can even separate
some identifiable, others left me wondering if the earth itself has electric frequencies
in addition to the dc-drift components.
jojo500
Quote from: sm0ky2 on January 05, 2018, 10:24:07 PM
yes and no . take that 1turn closed coil from barbosa ore the coax from tariel  an look at it as a magnetic loop ore box antenna
yeah i know they normaly use a variable air cap to tune it. but you don't have to. take any pice of wire wrap it a few turns over your loop say 3-6 turns and run it via a cable to you earth point .  Now with the lenght of your cable that runs to your earth ground you can tune your main loop verry easy. This was verry comon in the late 60 and 70 in east europe( russia) at the time they build medium to shortwave  tx stuff mostly for military aplikations. How ever those sort of contraptions have a wide variaty of build buildforms (a loop antenna made from coax is one of em) . thats all i want to say about it i feel it be wrong too  go deeper in this because it would not help too much for Zeitmaschienes work.
all the best
core
Nice job pulling information off past threads Zeit  8)
Regarding grounds, what do you do if you are in an airplane? I suppose the planes frame would have to serve as ground. That said what we call ground in these units should be refereed to as a mass. Same would apply if you are in space. Somewhere in my notes I have a quote from Leal stating the Ground is held at a negative potential. If I find it I will post the entire article, last I researched these guys in 2017 they had an enormous amount of legal issues. Some public court papers I saw from Brazil had them going to court almost every month. They have since started a new chemical company. Sorry can't remember the new name of the company.
If you step back even further in time you have Clemente Figuera, in his era there was no diodes, vacuum tubes, transistors etc.. So how simple is this.
-Core
