Paul-R
Quote from: Thaelin on November 20, 2017, 03:45:02 AM
Centrifugal force is your friend, use it.  Natures best. Next is a good old lever. put those two together and you can move mountains.
This is hardly a method to move forward with.
memoryman
" Centrifugal force is your friend" considering that Centrifugal force is an APPARENT force, not real, I don't want an apparent friend, but a real one.
a_user
NEWS
http://www.mooieenergie.nl/
Newsletter January 2018
History
Back in 1996 we got interested in the process of transforming the energy/power of gravity on objects into kinetic energy, ultimately resulting in a continuously driving force.
Patiently and motivated we continued working on the solution for more than 10 years, despite all external opposition and negativity (always blindly referring to the laws of conservation of energy).
More than 750 days ago we had a major breakthrough with a new invention. And last month we achieved our goal: We can transform gravity into a driving force; 100% kinetic energy, generated from the quadratic acceleration of weights in our "AirGravityMill", driving a generator.
Invention
With the special invention of the M.D.S. system, a primary active flywheel (that we call the "AirGravityMill") can drive a secondary generator.
The special weight-lifting capabilities of the invention generate 800% more energy than the energy that is needed to generate and control the free fall of weights in the "AirGravityMill".
Production
With the help of intermediaries, external companies and the growing interest of investors we now aim at producing 50 machines with a 250 KW to 1 MW capacity by the end of 2019.
We want to install and operate "energy islands" for the regional industry, producing and supplying our "Mooie Energie" (beautiful energy) where needed.
We estimate the "AirGravityMill" could ultimately drive 24 MW generators.
Introduction
Towards the end of January our system will be introduced in The Hague and Brussels (the political capitals of The Netherlands and the European Union respectively).
Product information
The "AirGravityMill" is a 100% closed pneumatic/hydraulic system and therefore does not require special permits. Depending on the capacity of the generator local authorities may have to be notified, or the system can be operated using the business license of the host of the "energy island". The system can be installed in a barn, warehouse etc.
Location
Only air and gravity are required. Therefore the system can be installed stand-alone. The only limitation is the accessibility of the location to install the system.
Of course there is no danger for surroundings or environment. Our energy production method is cheap, local and completely independent. The energy island can generate energy on a small footprint.
Characteristics of the "AirGravityMill"
100% constant capacity
Can be linked to own or existing (public) infrastructure.
Independent.
Can be installed almost everywhere
Low energy price for (power) consumer.
Quiet and safe.
Can be easily switched off and restarted.
Very small footprint compared to other systems.
Remote control and monitoring.
Environment
From mid-2018 we will first power our upcoming production facility with an "AirGravityMill". We will then slowly expand and provide beautiful and affordable energy to surrounding regions.
We will help to:
Provide cleaner air to breath.
Reduce "horizon pollution" and reduce nuisance for surroundings.
Increase safety.
Return the huge footprint of solar plants to agriculture, nature etc.
Our challenge
In the next 30 years we want to become one of the largest energy suppliers and install our systems around the world.
a_user
Even more news:
QuoteWe understand that the news about our AirGravityMill raises a lot of questions. You will understand that we are careful when providing information about our intellectual property. Nevertheless we will try to answer the most important question.
Question: How is it possible that, with just a minimal amount of external energy, the mill can drive a secondary system with 100% gravity?
Answer: The AirGravityMill is equipped with at least two "MDS" systems, one per mass. The working masses in the mill are set in motion with a small amount of external energy, activating the MDS systems. The 'law of conservation of energy' will make sure that approximately the same amount of energy remains in the mill for the next rotation. But the motion of the wheel and thus activation of the MDS systems has additional consequences that do not take energy from the rotation.
The MDS systems in the AirGravityMill will shift the masses to a height exceeding their starting positions by several meters. The "Inertia attachment points"* of the working masses (weighing 1000 to 15000 kilograms) are lifted to a higher position, generating potential kinetic energy.
One of the phenomena is that each mass wants to move up to 40 degrees of arc above the top of the AirGravityMill. Of course the mill will guide the mass along a fixed trajectory, so it can use the energy that is released in the free fall (quadratic acceleration). The energy is used to compensate the resistance on the side of the mill that is moving upwards. The remaining energy is used to drive a secondary system.
*The inertia attachment point is the position (anchor-point) where a mass would settle if the mill was stopped. Several anchor-points are used during the rotation.
sm0ky2
Multiple displacement systems, such as the chaos-pendulum
or Vikram's "see-saw" found in another thread,
utilize a difference in gravitational potential across a differential
of radial displacement.
The "net energy" remains in a zero-state, however, internally,
the system can fluctuate through ranges of internal energy
much higher than that which initiated the motion.
The assumptions that energy can be extracted internally from these
"high energy states" seem logical.
However, at least in the case of the chaos-pendulum, doing so disrupts
the initial energy to the point of system decay.
