Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Belfior
I think Kapanadze's secret was already in his magnetic motor https://www.youtube.com/watch?v=3thvqFhFIfY&t=188s
Toroid xformer, PC power supply and something under a circuit board. Doesn't matter how the motor turns or the generator works. That setup powers from a battery and then keeps powering the motor
I think he realized someone could figure this out and the the next videos are aquariums and other shit with old TV-panels painted black and extra wires up the wazoo.
Ground cables going through scrap metal coils and going into his know-how box.
tomd
Quote from: Fernandez on February 10, 2018, 12:19:32 AM
                                                ****************   February 9th 2018   ****************
User Zeitmaschine, I am going to give you credit, you put a lot of effort into your posts (even though you are wrong) BUT I want to put you and some others in this world on the right track and moving in the right direction.
Here is the truth, take it or bury it
I will keep this short and drama free, the words Free Energy, Overunity, and Zero Point Energy has corrupted your thoughts because the device is............ so easy you will laugh
For starters your statement is incorrect Lenz's Law is actually a blessing, you need to wrap your head around that first. Let's review Lenz quickly
All of you globally have missed the key word in that statement, you are too quick to denounce Lenz's Law as the culprit, the destroyer of energy. However, if I highlight just one word in that statement we open up a new method of utilizing Lenz's Law.
So the beauty is, if I create a magnetic field in a coil with some current NATURE rewards me with a duplicate magnetic field that opposes mine. Already I got something for almost nothing. (BTW... that's my first Primary coil usage, to create a Lenz induced field)
So I now have a Primary magnetic field that gave rise to an induced magnetic field as stated by Lenz. Pay close attention here, this is important! Now take another coil (call it Primary 2) and feed your Lenz induced magnetic field so you complement its growth. So in other words your North pole of Primary 2 faces the South pole of Lenz field (or Vice Versa). Because Lenz is only present in change of original magnetic flux. Are you starting to see? Lenz has no interest in my second Primary because Primary 1 is the parent of Lenz induced field. You really need to appreciate how powerful that statement is. Ignore what has been written in any other thread that talks about these devices, lots of people using big words and way to complex algorithms to build something a child can assemble.
So do you now understand why Barbosa and Leal explain in their patent the pole of the induced complements the primary pole? Do you now understand why that guy Tariel says........ it's so easy you will laugh, see why Clemente Figuera said "this is like the egg of Columbus". Because it really is that silly and simple, you simply feed the induced magnetic field with another magnetic field. There is no Lenz that opposes Primary 2, Primary 2 doesn't create an induced field (if you time it right) it ADDS to what has already been induced from P1. The result is a strong Rectified Magnetic field. That is your resonator, not so glamorous now that you know how everyone including Steve Mark pull this off. I apologies if you where looking for something more complex or other worldly. Unfortunately many of you will still be looking for a more complex solution because your mind will never accept such a simple solution to a problem that had you perplexed for years.
That is the theory behind the how it works some of you are smart enough to figure out the build details, but I will get you started. You are going to wind you primary's like a Poly-Phase motor (Yep a Tesla invention) take special note that a capacitor is used to delay a phase (this is super cheap and EZ). These devices use impulses and you need to split the wave in half so diodes are used. So one coil is at its magnetic max while the other is not, also you need to split the wave between coils, so half wave per primary but that is why you are using diodes (or tubes if your that type of guy Steve). Timing is very critical between the coils, remember you are building a resonator and nothing more.
Like I said before, take some iron from a tire jack and cut the ends off. Get a C-clamp to close the ends and you have a simple core that allows for different coils. To extract you need a secondary but that is simple, wrap it around your low budget iron core, use a thick or thin secondary.
So its up to you and figure out if the primary's should be CW or CCW, shouldn't take that long. BTW... bifiler coil doesn't mean crap.  The beauty of this device is different inputs (voltage/frequency) changes the output and output varies based on type of coil. Start simple, low voltage and don't kill yourself. You have more in this post then you ever wanted.
One more thing, Tesla patent, 413,353 not glamorous and not your FE but excellent facts and my personal opinion is as close as it gets for Tesla.
For those interested. This is the best explanation of back emf and transformers I have read. It's only one page so wont take long to read.
ramset
tomd
nice simple Doc
can you find one on  resonators ?
Fernandez quote from your above repost
and  some ? instructions from Fernandez ....[there are more instructions in other posts he has made here in the last 4 years]
End quote
respectfully
Chet K
PS
still getting feedback from persons on this build [the resonator part
No tire irons have been harmed YET...
when that happens it will happen here in a dedicated thread
* first a schematic will be proposed for discussion... to accomplish this "Fernandez resonator"
Thanks Grandma
norman6538
The Lenz factor has me confused but I want to add what I picked up from the
Bouforn patent....
it says in my words the coils protrude inside each other...
in his words...
either both opposite sides of its core will be into hollows in the corresponding
inducers and in contact with their respective cores, or either, being close the induced
and inducer and in contact by their poles,
but in no case it has to be any communication (contact??) between
the induced wire and the inducer wire.
a. into the coil - not  core hollows (remember this is a spanish to english translation so
the words will not be the best)
b. no contact with each other ( translated uses communication)
Did  I understand this right?
Norman
tomd
A couple of links that may be helpfull.
1. Tesla patent 413353 mentioned by Fernandez: https://teslauniverse.com/nikola-tesla/patents/us-patent-413353-method-obtaining-direct-alternating-currents
2. The Qeg2 which I believe has been modeled on patent 413353. The blog was started in 2016 but for whatever reason came to an abrupt halt: https://qeg2.wordpress.com/2016/01/25/introducing-qeg2/
