inertial propulsion with gyroscope
Started by woopy, January 16, 2018, 04:39:01 PM
woopy
Hi all
to Tinman
Hi Brad  i think that the boat you linked is a thornson device which is rotating dead mass , not gyros ,so far i now. and i don't now if that system can exhibit some gyro property as it seems to go forward on the water.
to Steven jones
Yes you are a very good observer, and M. Fiala in the patent explain the slight back movement before the stronger forward movement.
To conrad
Don't be so sceptic it is very bad for the health. And please go forward in your research that's make happy even if we fail.
To all
my latest try. A lot to test for the near future.
https://youtu.be/1Grv5B7AqkE
hope this helps
conradelektro
Please watch this video https://www.youtube.com/watch?v=Im2mNnWZ5Oc
It is not from me, I found it by chance on YouTube, but I think it has something to do with the Fiala patent. Gyroscopes are very interesting and hard to explain.
I gather from the above video that there is a difference between turning a dead weight or a gyroscope in a circle. The gyroscope will want to "nod" and a dead weight does not "nod". And the gyroscope "nods" if only a very slight turning movement is initiated. Therefor I think Fiala only needs a a very slight lifting with his rail.
@Laurent: your latest video "inertial propulsion with gyroscope part 9" is a very clever modification. If you watch the video which I mention above, you will see that it only takes a very slight turning movement to make the gyroscope "nod". Therefore the Fiala device could may be work with only a very slight turning back and forth, as you do in your latest experiment. I hope that I will be able to do all that with my stepper motor design. But building something is so much work, I just have collected some components which I am going to use.
Greetings, Conrad
DrJones
  I also enjoyed the latest video, #9.  Clever modification!  Was that idea yours - or was it in the original patent?  [/size]
[/size]
Also, I especially like the sequence beginning about 1m14s where the device goes back a little, then untouched accelerates forward (to the right in the video).[/size]
DrJones
  There are several ideas out there for inertial propulsion...  I like Laurent's clear demonstrations the best.
For the record, though, I would show this approach from China:  https://www.youtube.com/watch?v=UUf4EG8tFE8&t=151s
sm0ky2
@conrad
That's silly.....   "one would have heard"
The only ones that would have heard would possibly
be scientists studying inertial propulsion.
And people like myself that went to live demonstrations.
The one I was referring to was in the 80's
not sure if it made it onto the internet, as it predates
the internet. (we were still using the bbs system)
Inertial drive research was, at the time, mostly restricted to
to NASA and LNL researchers.
The demo I was invited to was a NASA team, and the boat was a toy
in a pond.
The rotating weight had an arm that was able to extend at a portion of its
rotation, then retract shortly after.
Allowing it to transfer centrifugal force in a linear direction.
Like swirling a weight on a string, then jolting your arm forward
as the string passed in front of you.
Was a solid arm, not a string, but the analogy is valid.
Similar to catching a sling-shot projectile, shortly after it is released.
