Successfully looped SMOT
Started by postingsite, January 23, 2018, 09:58:00 PM
synchro1
New new fast food franchise: Tinsel Kenturky Fried Chicken.
I added a new comment to my negative inductance and magnet field thread to help.
postingsite
     So maybe there could be an Electrostatic version of an SMT,  but much more difficult, and there'd be no point if a  magnetic one loops continually
      Note,  the video moves around in the the 2nd scene,  so I doubt there has been any editing
postingsite
  I  didn't  know that there may also be some  Solid-State  overunity-self-powered generators actually available,    but still,  since they're not recognized outside of where they make them,  which would give them all the protocols( etc ) of normal products,   it makes it very difficult to consider buying one
   Although,  for those people who personally know( close friends etc ) people who have received a functioning product,  they would hesitate less,  since they can then inspect it etc,  before buying one
_____  _____
   @sm0ky2
     sm0ky2 mentioned on a thread that when he applied current to 2 hollow metal-spheres, that they remained locked together after he disconnected the current
       -  Maybe it was 'Electro-Static-Charge-Seperation' , and maybe the sphere's also held the charge inside ,  unless it was something magnetic or electromagnetic
      It would be excellent if we had some links or diagrams about the    "singular-pole magnetic beam. (magnetic laser)"    that   sm0ky2  mentioned,    but some of those   tri-force  threads have too many pages to read through
       If it is correct that the magnetic-field is actually the  electric-field,  then maybe an  'Electros-Static'  version of the  'Permanent-Magnet-Laser'  mentioned  by  sm0ky2  could also be achieved.
         I say that,  because I wonder if inside a highly  positively-charged  piece of styrofoam( electret ),  if there is an equally( ? ) high negative-charge(  inside of the styrofoam( electret ),   which is similar to a  Permanent-Magnet
postingsite
Quote from: postingsite on February 22, 2018, 03:19:47 PM
    I forgot to add,  that in order to make an 'Electros-Static'  version of the  'Permanent-Magnet-Laser'  mentioned  by  sm0ky2,   you would have to push a  postive-electrostatic-charge  to one side of an electret( eg. styrofoam ),  so that the electret( eg. styrofoam ) would have an 'Electros-Static'  N and S pole  .
sm0ky2
Maybe not.....
From what little could be learned from the magneticnlaser experiment
is was a field compression effect
It can be done with the magnetic meridian, as well as either pole.
But the simplest form
was n-n-n
or s-s-s
Repelling each other, until the center field collapsed into a finite beam.
Which suggests that, yes we should be able to do it with 3 charged conductors.
using electrostatic fields of either polarity.
The test should be simple enough
The way it works is: two fields approach from an angle on each side
Like from kind of behind the 3rd field
Like the shape of the two-force
But using 3 like poles on one ball
So electrostatically, it would be 3 charged spheres in the air (not touching) but forming a triangle
Basically forcing the charge in.the sphere to the outer curvature away from both of the other 2
The 2 approaching spheres should be further from each other than they are to the 3rd
so the more to the sides than a perfect equilateral triangle
There were different approaches, with varying degrees of success and failure
But that's the basic idea behind it
Force the like-polarity into a small space (compress the field)
and it stretches out into a line instead of looping around through space like it normally would.
