170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
ramset
Note
Did just speak with GotoLuc {Luc]
he is going to reach out for Pierre
respectfully
Chet K
Thanks Grandma
gotoluc
Hi guys,
I sent pedro1 (Pierre Cotnoir) a private massage (in French) to welcome him and offer my help with translation since my mother tung is French. Looks like we are both French Canadian.
Hopefully we can talk on the phone and I can help answer some questions.
Luc
listener191
There are multiple patents that cover rotating/traveling wave magnetic fields, that purport to be OU/self powering.
One of these patents is attached. I built figure 14 from this patent (attached image), which is one of the simplest implementations. This was about nine years ago.
At the time I never had the right equipment to analyze the power from the two phase output.
I assumed at the time, that lenz would have to be circumvented for these schemes to work.
Also attached is a linear version of the 3 phase transformer described in the patent (the last few steel sections missing). I can confirm this variant showed no remarkable performance and it was clear that a closed stator was likely the only way the operation described, could be reproduced.
L192
listener191
I think I can see how the pulsed stator sections are achieving the apparent OU effect.
The angle of flux arrival into the central core section is changing over time however, the CEMF associated with the load is directed back into the stator at largely the same fixed angle. Although only a single coil is being pulsed at any one time, the flux will also couple back to the other side of the central core via the stator.
At the point where the CEMF flux couples to the stator there will be a phase difference between the two fluxes. Essentially the CEMF does not cancel the energizing flux, in fact it may even reenforce it if the phase difference is sufficient.
The efficiency would be a limited by a single central core coil. I would think three core/coil  sections spaced at 120 deg would do better.
Being a pulsed system, energy recovery is also possible when each coil turns off.
The three phase transformer patent, based on an induction motor stator, is harder to explain however, perhaps there is a flux circulating in the stator that is being reused.
L192
konehead
Hi L192
Thanks for the good theory why and how it works.
Okki from Germany just gave me good idea in an email to me today;
why not try this with a car alternator?
Just to see the effect and what happens with that....anyways this a pretty good initial simple experiment to try - the pulse to stators could even be done with timing disc with small magnets on it, against hall effects to trip mosfets or just do the arduino if you have it and know how...
konehead
