170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
pmgr
Quote from: Erfinder on March 09, 2018, 04:58:29 PM
Gentlemen,
Sorry folks, but if the schematic that Konehead provides is a true accurate account from the source, somethings not right, the statement at the bottom, the drawing, and the number sequence paint a very different picture than the one that you all are discussing... and agreeing on!  WTF folk!
there are:
7 coils per group NOT 6!!!
5 poles per coil
6 slots per coil
example....
red group.....numbers refer to slots....
1-6, 6-11, 11-16, 16-21, 21-26, 26-31, 1-32 = 7 coils!!!
Konehead himself noticed the gap in the coils, but did not notice that the total number is 7.  This is important because it means two coils will have the same magnetic orientation at the gap, a point in the magnetic circuit where we find a coincident pole.  That said, inside the alternating field, focused at one single pole, the magnetic field bucks....  That changes things, everything... especially when you consider there are 5 phases (not 6...  72° magic number...)....  rotating field....can you see what's rotating...
some are jumping the gun too quickly.....  Its unfortunate that I am the first to see this, those who have started building are for the lack of a more professional way of stating this....FUCKED...
The thought that was invested in the 5 fold symmetry, and its use in forcing a non linear relation within the magnetic circuit leads me to suspect that this guy is way more clever than the folk trying to figure out what he is up to.......LOL
Here's the fucked up part....  I caught this, but I am not going to get the credit for it....
Erfinder, I believe you are correct. Also Koneheads upper left drawing seems to be messed up in terms of colors and connections (?). E.g. the 26-31 connection should be red, the 27-32 connection should be black, 28-33 should be blue, 29-34 should be green, 30 to 35 should be yellow.
Then going from the upper left corner to the upper right corner, red 36 should get connected to yellow 5, black 32 to to red 1, blue 33 to black 2, green 34 to blue 3 and yellow 35 to green 4.
Anyway, using the magic numbers, there are 7x5=35 contact points which makes sense with why his transistor board is arranged in a 5x7 transistor layout (yet two more transistors appear to have been added later on and transistor 35 never goes on as stated before.
Maybe connection 36 is a relay for a ground connection?
A bit confused now. Let me know what I should model next....
PmgR
pmgr
We are over-complicating things (excuse the pleonasm). I think L192 was correct from the start. There are 6 poles, NSNSNS and they span the 36 slots. Each of the windings spans 6 slots.
Then there are 3 phases, each phase firing up two coils for a total of six coils (hence also the six blue LEDs that light up in 3 pairs of 2 at a time).
First coils has windings near slot 1 and slot 6: magic number 1-6
Second coil has its windings near slot 2 and slot 7: magic number 2-7
Third coil has its windings near slot 3 and slot 8: magic number 3-8
etc.
Coil 36 (last coil) has its windings near slot 36 and slot 5: magic number 36-5
Each magic set is biased 180deg out of phase with the previous set.
This will create six poles N-S-N-S-N-S.
Then stepping through the poles will provide the spinning field.
Attached is a quick simulation of the field. Will run a full rotation shortly and make an animated GIF.
PmgR
* Truthfulness * Compassion * Forbearance * www.falundafa.org
pmgr
Here are two simulations (2 different speeds: 0.075sec framerate and 0.125sec framerate, please provide feedback which delay works best for you). Hopefully they will upload correctly...
Interesting thing to see from the simulation is that when a N-pole and a S-pole face each other through the center coil, they prefer to directly fold back on themselves through the stator instead of going through the center coil (see attached image). Also note the clearly distinguishable 6 poles with each pole switching its field direction (SNSNSN).
Edit: looks like the upload is still not working. Find a zip file attached instead. Unzip with powerarchiver and ignore any CRC errors.
PmgR
konehead
Hi all
Pierre is watching discussion here and that is why he sent me the magic numbers list I think so anyways as some were going in other direction in ideas how it works and Pierre wanted to get everyone on right path of what he does
Maybe some other methods will work you will only know by bench testing but as far as what it is that Pierre - did that is in His magic number list.
Pierre did not do the colored wire connections I did that and like erfindef noticed it gets fucked up around th 31 to 32 slots  - sorry I would write "poles" instead of slots- and i am glad i did those colored connections as it really sheds light on the sator connection pattern being not so logical and predictable instead it gets fucked up around pkles 31 32 and note how tbe color pattern must change just tbere at upper lef as erfinder noticedt
This is "how it is" according to magic numbers provided. Pierre is trying to help understanding this is good ....now I wonder if stator of stock 3ph motor needs to be rewound like this or not.
Pierre states 6  magnetic fields rotate co that is th nsnsns 6 pole sequentially pulsing going on. I dot think the rotating pulsed field is done in three phase it is 6 poles nsnsns spinning around this Pierre wrote so take his word for it eh
konehead
Hi Erfinder
Just to clear up things, here is the exact message I got from Pierre:
"hello, the magic numbers are 1-6,2-7,3-8,4-9,5-10,6-11,7-12,8-13,9-14,10-15,11-16, 12-17,13-18,14-19,15-20,16-21,17-22,18-23,19-24,20-25,21-26,22-27,23-28,24- 29,25-30,26-31,27-32,28-33,29-34,30-35,31-36,32-1,33-2,34-3,35-4,36-5 this is not 3 north or south pole, there are 6 pole 3 north and 3 south alternately you should review the magnetic field simulation it will never work with your configuration"
I edited out the last sentence, since it is confusing the translation, )as the magnetic field simulation posted on the board, is not "my" (yours) configuration but rather others idea.  Substitute the word "that" with "your" in his statement and it makes sense .......he is saying that magnetic field simulation will not work, and I should "review" it....by reviewing it, I think he means to take another look at it, its will not work!
Also note Pierre says "this is not 3 north or south pole".... "like first simulation....
Anyways it is important to note there are TWO things being described - first is the stator wiring connections and how that is done.....so I had sent him that simple 36 pole drawing I did earilier, with no connections just 1 to 36 poles" labeled around it, and I asked him when looking at that drawing, what are the corresponding numbers on how the stators connect???
So Pierre answered that question plain as day - and he gave the magic numbers and this is how the stator wiring connects.......
Now the other thing we are looking at is just how is that rotating sequentially pulsed field pulsed, in what pattern/shape is it?   What polarities?
Now here, Pierre has already explained on video it is 6 magnetic fields rotating....
So now we know from this message that it is a 6 pole magnetic field, and these poles are configured NSNSNS since he says NS alternatively....
So now it seems you need to send a pulse in through #1 and out #6 (as example)....then go over to the other side of stator, and send a pulse through (in opposite polarity than 1 and 6) and figure out which wires are exactly 180 degrees across, and that is one of the three pulses going into the stators, that rotates....now just go over 60 degrees do the next position, send in power one way on one side and opposite way on other, then go over again 60 degrees again and do it all again there....so this will complete just one pulse of the rotating field, now it is just matter of doing it all around the stator timed to create the sequentially pulsed rotating field....I will "assume" it goes one pole position at a time for 36 pulses per revolution but maybe only 35? considering how the stator wiring pattern goes out of logic around poles 31 and 32 but who knows maybe this is common way 3ph AC motors connect their wiring I  don't know.
Anyways I know Pierre does not want to give out his email or his phone number and I am sure Skype too, you can imagine how he would be besieged and he also works day job 60hr weeks too Luc said as well....
I think on his youtube comments section is best place to contact him, since he is in control there, it is his video and he has no pressure there and for example the  intense scrutiny he would get here....but still he is watching, so that is good and he wants us to know how it works too which is also good you can also imagine how difficult it would be to explain to everyone (at least 1000 wuestions to answer and half of people will not understand and have it backwards or whatever) I hope my drawing helped a little bit and saved him some time....
So anyways, I just read again your questions Erfinder......I think you might be a bit confused in what his description is - and like explained here the magic numbers correspond to the stator windings....the "NSNSNS" 6pole thing corresponds to the rotating field pulsoing....
Also don't worry if I get anymore info I will post it....you should review the comments in his youtube videos and see what he says when he replies to people to get some more info too.
