listener192
Attached represents about the best we can do for a 30 or 36 slot stator whilst generating 6 poles.
So in the case of the 30 slot stator it would be 4 coils at a 3 slot pitch and for the 36 pole stator it would be 4 coils at a 4 slot pitch.
I have added Pierre's  36 slot stator 6 coil scheme. I think semiconductor switches will have a hard time with the clashing poles.
L192
gotoluc
Good morning everyone,
Just to let you all know that 2 new members have joined, so their posts were not visible and waiting for my Moderator approval and Listener191 also had an email issue which also needed moderator approval.
So please see all posts above to read these now visible posts
I will also be translating Pierre's new PM he sent me. So stay tuned for those updates.
Luc
Fr.
Bonjour à tous,
Juste pour vous faire savoir que 2 nouveaux membres ont rejoint, donc leurs messages n'étaient pas visibles et attendaient l'approbation de modérateur et Listener191 avait aussi un problème de courrier électronique qui nécessitait également l'approbation de modérateur.
Alors s'il vous plaît voir tous les messages ci-dessus pour lire ces messages maintenant visibles
Je traduirai aussi les nouveaux PM de Pierre qu'il m'a envoyé. Alors restez à l'écoute pour ces mises à jour.
Cordialement
Luc
gotoluc
The below are two new messages I received from Pierre after he viewed my last French video.
Fr.  Ci-dessous son deux nouveaux messages que jai reçus de Pierre après avoir vu ma dernière vidéo française.
Yes, I know that 6 pole without current variation does not give much but my device has a variation of current. Congratulations you just discovered one of my secret. There still remains more to discover, then you will see the performance I achieved. And yes, there is really 6 field that rotate, except, there really is a variation which you need to know how to do so you can vary the coils. It may be possible that your configuration can achieve it but I'm not sure of your configuration, you will need to experiment. One thing is sure, if you had 5 pole it will not work. You see, you start to find solutions to the problems.
Sorry, I had left you a quick message since I was not home. Yes you can make a fluctuation between the field while having 6 magnetic field and can be all done in series. I was able to do it it. There are several ways to do it and you could have done it with only 2 pole in series, 1 north and 1 south with all coils on.
I would of needed to considerably increased the speed but with relays it is not possible. You can do it as you want but it is one of the conditions to get overunity.
You still have one solution to find but the basis is to have a good rotation of the field, a north at one end of the rotor and a south to the other side and a variation of current if you want a maximum of amperage and it's better kept all the coils in series in this configuration but you really are on the right track. Now I understand why you did not have much output with the program that I saw. Everything is explainable. Have a good day
Fr.  Oui, je sait que 6 pole sans variation de courant ne donne pas grand chose, mais moi j'ai une variation de courant. Félicitations tu vient de découvrir un de mes secret. Il en reste encore un peut  a devouvrir et tu va avoir le performance que j'ai fait. Mais oui, il y a vraiment 6 champ qui tourne sauf qu'il y a bien une variation, suffit de savoir comment faire pour varier les bobines. Il se peut que ta configuration faisse le travail mais je ne suis pas sure de ta configuration, tu peut experimenter. Une chose est sûre, si tu avait 5 pole cela ne fonctionnera pas tu voit, tu commence à trouver des solution au problème.
Fr.  Bon désolé, je t'ai laisser un message rapidement mais je n'était pas chez moi. Oui tu peut faire une fluctuation entre les champ en ayant 6 champ magnétique et tu peut faire toute en série. Je l'ai fait. Il y a plusieurs façon de faire et tu aurait pu faire avec seulement 2 pole en série 1 nord et 1 sud et toute les bobine allumée.
J'aurais du considérablement augmenté la vitesse, mais avec des relais ce n'était pas possible. Tu peut le faire comme tu le veut mais c'est l'une des condition pour faire un overunity.
Il te reste qu'une solution a trouver, mais la base est de bien faire tourner le champ, un nord a une extrémité du rotor et un sud a l'autre coté et une variation de courant si tu veut un maximum d'ampérage et vaut mieux resté en série pour toute les bobine dans cette configuration mais tu est vraiment sur la bonne voie. Maintenant je comprend pourquoi tu n'avait pas grand chose a la sortie avec le program que j'ai vue. Tout s'explique.  bonne journée
gotoluc
Quote from: MichelM on April 15, 2018, 05:03:17 AM
Hello Luc,
did I miss something ; can you explain to me how is ordered the closing of the contact (green arrow) which allows the passage of the negative current?
Thank you
FR
Bonjour Luc,
j'ai loupé quelque chose ; pouvez-vous m'expliquer comment est commandée la fermeture du contact (flèche verte) qui permet le passage du courant négatif ?
Merci
Hello MichelM, please see the below drawing to understand how the coils are powered and connected.
Fr. Bonjour MichelM, s'il vous plaît voir le dessin ci-dessous pour comprendre comment les bobines sont alimentées et connectées.
