marathonman
 creasysee;
  I would not even consider swapping the poles on the Figuera device as it works fine the way it is. of course i have not tried it or even considered it as i was trying to build as close to the original as i can. the C core part G was just to eliminate the parallel inductance on the none active side and ease the winding as we all know winding a toroid is a total bitch.
I gave up  the electronic version because the amount of transistors required to mimic the brush rotation and that was money i can spend elsewhere.
yes i fiqured the loop back to part G and has been tested with no sparking what so ever.
the theft was a terrible blow that my ex room mate will bear the burden as i am suing him for the very pants he is wearing and then some.
I will be back in the saddle very soon but until then my partner in crime is Aetherholic on Hyiq as he now knows what i know and is almost finished with his build. together we will change the world.
Marathonman
marathonman
 creasysee;
  I really don't think Figuera had a split phase device and certainly did not have a ballast connected to it to balance the device as the patent does not even remotely mention the use of.
of course to day we could attach one to it but that is NOT the requirement of the device to operate.
Quote;
"So we cannot connect any load to the device."
completely false, there has to be a load connected to the device at all times in order for proper function. when a load is connected and current is flowing a second field forms opposing the first and it is known as the Lenz Law. it is this field this field  that the primaries push from side to side across the entire length of the secondary.
Yes keep things adjustable at all times as one misalignment could change the operation of the device and hamper it's output.
No load, no opposing field, no output, it's that simple.
and yes the device works in that range specified. no flipping of the domains like in ac.
Marathonman
creasysee
Hi Marathonman!
Quote from: marathonman on October 10, 2018, 11:13:14 AM
Full agree!
And sorry for my English. "So we cannot connect any load to the device." - I mean that the device will not work when the load takes very low power or takes very high power.
For example, we got the device working for 1kW. If the load 1kW is connected then a current produced from primaries can be stored in part G. If the load is 500W only then the current produced by primaries may not be enough for part G. Conversely, if the load is 1.5 kW, then part G can become saturated.
Thanks a lot,
creasysee
marathonman
Very much agreed, the Figuera device is to be designed specifically for the load intended with some headroom of say 500 va or there of.
Marathonman
marathonman
When there is a load increase the resistance on the output is reduced which allows more current to flow which in turn sends more current from the secondary feed back to part G. this will forward bias the core sending more current to the primaries which will produce more current in the secondary and the load. this is of course a slight generalization of the events that are taking place in the device. voltage is one of the aspects that is increased also when this scenario takes place.
Marathonman
