A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
1000 W to 270 W to 180-150 W object- + space-heating
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=202008006432&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
Waterheating with infra-red waves
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=45&ND=3&adjacent=true&locale=en_EP&FT=D&date=20080327&CC=DE&NR=202007016567U1&KC=U1#
George1, 2x fold efficiency in relation to conventional heaters does not mean C. O. P. : 2 by Physics  !
Radiation/Convection/Conduction heat has his dis-/ad-vantages  ! Each case his appropriate solution  !
To feel physiological well in cold climate our  individual body needs only an enclosure ( heat losts insulation) and max. electric 12 Watt heat power,
( in the 90' by thick cable- array 80 Watt,  reduced by nanofibers use to 12 W)
the rest goes to relatively uncontroled space and object heating  !
Beside ambient temperature the human genetical sensibility related humidity/ temperature/ moving air is not the same  ! ( Tests in dry air cryo- climate chambers with thermografical skinreaction comparison)
Writing about C. O. P.  is ever "Carnot thermo-dynamic cycle" related,  reaching the ideal point : eta=1,
an up to 99% ideal point near device : diode-array
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941018&CC=US&NR=5356484A&KC=A#
a quantum- mechanical heat pump
Classical Voltage to quantum eV( ancient erg/ dyn- unit) and thermalaccustic unit : dB = thermal noise
To understand efficiency and C. O. P.  I would recommend to study thermo- : Seebeck-/Peltier- elements,
for heating or cooling in use.
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fclausmeier.tripod.com%2Fstrahlg.htm
George1
Good explanations, lancaIV! Thank you very much for them.
1) But I was misguided by text, describing Mr. Filip's heaters. Actually it's a matter of a 50% decrease of the consumed energy as only the infrared component of the Joule's heat remains the same.
2) And the other misjudgment related to COP. Yes, I understand this. But actually this is a fault of those who write the related texts. They have to specify what exactly they mean.
3) About Seebeck-/Peltier- elements and effect. Thank you for this recommendation of yours! This is because some years ago together with a friend of mine we worked over a device based on Seebeck-Peltier effect. I will re-fresh my memory with pleasure.
4) Please give us some time to consider carefully the last posts you have sent to us.
George
George1
Hi lancaIV,
Thank you for re-freshing my elementary school knowedge. You made me younger for a while! :) Although many things in our educational programs as if have to be re-considered. For example: "When chemical bonds are formed, heat is released, and when chemical bonds are broken, heat is absorbed." Who has ever seen a chemical bond? Or an atom? Or a molecule? These are abstractions, which work well in many practical cases, but at the same time they generate much more questions than answers. (Of course, this is my personal opinion and I woud not like to press anybody to agree with me.)
Looking forward to your answer.
George
George1
Hi lancaIV,
Professor Kanarev's points of view and approaches are extremely interesting and original. It seems to me that (at least theoretically) some of his water-electrolysis-related research works unambiguously manifest outlet energy/inlet energy > 1. Keep reading.
What is your opinion about Prof. Kanarev's research works?
George
