Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 204 Guests are viewing this topic.
benfr
Quote from: a.king21 on July 01, 2019, 04:35:49 PM
I thought it meant laugh out loud.  Ah well you live and learn.
Anyhow I did not use capitals.. I was trying to introduce some lightness into the study.
So maybe use ha ha ha instead  (ha ha). :D
Sir, I disagree...you do not need to save from using words. Words do not circulate else than by the intent. Your intent was nice, so the energy which circulated. Buddha has stated about such things ; Masaru Emoto has even proven such manifestations. Be confident that laugh belongs to light ...
gyulasun
Hi Itsu,
Would you mind making a coil on a ferrite rod and use it at also to probe around the big coil? (like you showed it
with the small coil and single white LED in the video, after the VU meter tests).
Ferrite antennas mainly receive (and sensitive to) the magnetic components of EM fields.
This would verify the behaviour found by the small coil test (I do not know if it has a ferromagnetic core?)
Thanks,
Gyula
Jeg
Quote from: rickfriedrich on July 04, 2019, 01:19:33 PM
So the questions are, are those drawings representing what is happening, are if yes, are they the totality, and does all the energy transfer from primary to secondaries in a way that no gains are possible? Is there any point in asking these questions?
I think I understand your point. You are talking about the two energy storage mechanisms that exist and our bad habit to tap in just one of the two. Namely electric and magnetic field. Energy goes back and forth transforming itself in the two different qualities. The electric part is forgotten.
AlienGrey
Quote from: Jeg on July 04, 2019, 02:11:54 PM
Jeg do you mean dielectric? on a real device you need both and mix them for real power. ;D then transmit it !
itsu
Partzman,   Gyula,
I redid the test where the vertical satellite coil in front of the 2 horizontal satellite coils increased
their leds output while monitoring the input voltage / current into the gate driver.
It shows that the input current decreases (199.4 -> 195.1mA) when the vertical coil gets in front of both.
I also tested with the 2 horizontal coils next to each other, so in a horizontal plane instead of above each other
(vertical plane) and the results are similar with the difference that the vertical coil in front only reacts with the
horizontal coil directly in front of it (same input differences (199 -> 194mA).
Video available if wanted.
I also used a ferrite rod cored coil to do the magnetic field outline test which i did yesterday using a small
air coil in resonance and a blue led.
Also the ferrite rod cored coil (560uH) somewhat in resonance with a 1nF cap parallel with a blue led showed
similar behaviour, meaning when horizontal, a dip in the middle, and a peak in the middle when vertically.
Video here:  https://www.youtube.com/watch?v=-9dLj5MrAHY
Itsu
