Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
synchro1
Quote from: norman6538 on September 16, 2019, 12:57:26 PM
Gotoluc, I recently was working on permanent mag power by stacking and unstacking to get additional power and realized that Kunnel and Figuera were probably do that very same thing.
Kunnel powered his entire house but was not connected to the grid. And when asked did it work he said "yes but not as drawn".
I'm finishing up my permanent mag power by stacking and unstacking and if inadequate will turn to coils and permanent mags because you can control them better.
I used the Lafonte attract/repel balancing but found that magnetic spin made the attraction
stronger than the repel. I have compensated for that by distance but have not measured the results yet.
Norman
linear track
Each 1" axial magnet can be compared to a segment in a linear magnet track. The magnets are accelerating an electrical charge rather then an object. The description of "Thin (silver) magnet rods" connected to Hans Coler's generator is accompanied by a schematics of what appears to be an interlocking maze of magnet rods packed inside a box. Perhaps hundreds of axial magnets can be arranged in series and packaged neatly this way.
__________________
synchro1
                                                    Cook battery
Wrapping the coil around the magnet cylinders would copy Daniel Mcfarland Cook's patent.
I believe the cook battery may have used the magnet core as a hi voltage secondary for the interrupted backspike.
synchro1
        Gadgetmall
Gadgetmall went over unity with a piggyback output coil that collected the BEMF from a primary pulse coil that shared the same ferrite core.
The magnetized core amplified the backspike.
A neutralization pulse on a GAP motor coil would recover amplified backspike if the magnet was extended and wrapped with a piggyback backspike recovery coil like Gadgetmall, that worked wirelessly through induction.
synchro1
The Karl Schappeller Device "Stators" are grid patterned magnet conductors. The spark gap must be tungsten coated. Two large magnet core coils amplifying the kickback first one way then the other. Nearly Identical to Hans Color's design.
The Danial McFarland Cook battery is nearly the same: You can see the four coil wires attached to the protruding core electrodes with wing screws:The power of Cook's battery is directly proportiona to the length of the magnetic conductor core between the electrodes.
The schematic does not show the interruptor. Each coil recycles accelerated kickback through the other's magnet core. Cook suggests cores of four feet or more in length.
synchro1
core length and negative resistance.
quote;
"It strikes me that a Fe core that is between 2ft and 6 ft long will have significant magnetic delay which brings me to the subject of delay lines that have reactive characteristic impedance. These can exhibit negative resistance, so maybe the device used this characteristic and once started did truly self-oscillate. That gives a new perspective to the thing. Is it possible that the core length plays a vital role"?
