Food for Thought: Our World
Started by SeaMonkey, December 05, 2014, 04:21:55 PM
onepower
Floor
Thank you for the well thought out response and I believe you hit on most of the important concepts.
Energy is the capacity to perform work and work is (F x D) or a force which is the cause for something to move through a distance. However we could say energy is motion as an acceleration, as constant motion we call kinetic or a deceleration. In every case energy is motion or a change in motion to everything already in motion on some scale. Thus, as many physicists simply say... the universe and everything in it is energy.
This is the very premise of FE and there was never any need for creation/destruction or something from nothing which is a false narrative. Everything is already in perpetual motion which is energy thus the only real question is what is the most practical way to transform this energy into a form we want.
As many famous FE inventors implied, it is not so much a matter of thinking about energy but knowing it. To know and understand everything is energy despite our mind and senses trying to convince us otherwise. For instance in my world there is no static only dynamic and what others see as stationary I see as having incredible energy as motion. It is something we learn to embrace as a universal truth and apply to every aspect of our lives.
As such when I go to the bench and build I do not have to wonder where the extra energy could come from as I already know. It is everywhere in everything and my only concern is how to transform the various forms of energy already present into another form I want. I found it very difficult to change my perspective at first and I had to keep telling myself everything I see as stationary is a lie and I know otherwise, there is no static only dynamic. We keep repeating this, we keep seeing things for what they truly are and after a while it becomes intuitive to us and we don't even have to think about it, we know it.
People are not born doctors, engineer's, scientists or other professions it is something they learn which then becomes normal and a part of who they are. FE technology is no different and it is simply something we learn and accept over time. Most people cannot succeed at FE because they refuse to accept it and what they do is akin to trying to build a wind turbine without knowing or understanding the wind. They would build there wind turbine inside a house and tell everyone it cannot work for reasons they do not understand.
So now we know everything is in perpetual motion and this constitutes free energy. Now the next step is choosing the form of energy we wish to transform on any given level and devising means in which to transform it to the form we want. The most common is thermodynamic energy or heat which is a form of molecular motion. The molecules are oscillating and if we can coordinate these small motions into a larger unidirectional force it will produce a larger tangible motion we can measure. This is why many of these devices produce cooling effects and they are not unlike a heat pump in there action. It just so happens that the "pump" is the oscillating molecules and there motion is mechanical in it's nature just like a compressor pump. As above so below and all energy is motion thus in some sense mechanical on the level the motion occurs.
It's not hard to understand we just have to learn to see it for what it is.
DavidWolff
If you listen, talk, watch Eric Dollard's vids you would have realised by now the Electricatee syndicate has been generating the stuff and using resonance and selling zero pointy energy since the 60's
Are you going to ask for a refund ?
                                       https://de.scribd.com/doc/226463563/Mandelstam-Papalexi-On-the-Parametric-Excitation-of-Electric-Oscillations-1934-NASA-1968
                                       https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FFerdinand_Braun
                                       This rectifier effect on lead sulfide crystals contradicted Ohm's law, but was hardly noticed.
Among his students are Jonathan Zenneck  ;) , a pioneer in ionospheric research , as well as Leonid Isaakowitsch Mandelstam and Nikolai Dmitrijewitsch Papalexi as the founders of Russian radio frequency technology . Max Dieckmann was a doctoral student and assistant to him.
                                       https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FCarl_von_Linde
             The Linde process uses the Joule-Thomson effect  and is based on the countercurrent process With this, Linde created the possibilities for physical low-temperature tests and for separating the air components by fractional distillation
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FJoule-Thomson-Effekt
In connection with the discovery of the first and second law of thermodynamics around the middle of the 19th century, the balance of work and heat in the compression and relaxation of air was examined with increasing measurement accuracy.No temperature change had previously been detected in the Gay-Lussac experiment when air expands into a larger volume without heat flow and work performance as the pressure drops.Accordingly, their internal energy does not depend on the volume.This was verified with greater accuracy in 1852 by James Prescott Joule and Sir William Thomson (later Lord Kelvin ) by subjecting flowing air to a controlled pressure reduction. For this purpose, the air was pumped continuously through a thick, long, thermally insulated pipe with a small aperture halfway and showed a small cooling at the other end.According to their publication , this change in temperature is referred to as the Joule-Thomson effect.Since the equation of state of the ideal gas would result in constant temperature, it was also established that air is not exactly an ideal gas.The van der Waals equation of state presented in 1873 fits better and results in a weak volume dependence of the internal energy.The Joule-Thomson effect was made by Carl von Linde in 1895 as the basis for technical air liquefaction and the production of pure oxygen and nitrogen.
        Hilsch_Ranque tube !  https://en.wikipedia.org/wiki/Vortex_tube   turbulent to laminar or reverse
https://translate.googleusercontent.com/translate_c?depth=1&hl=de&rurl=translate.google.com&sl=de&sp=nmt4&tl=en&u=https://de.m.wikipedia.org/wiki/Van-der-Waals-Gleichung&usg=ALkJrhj9kQw8_mQSWHXj7S8y3FQYtFLgyA
the Van der Waals equation contains two parameters for the repulsive and the attractive forces between the gas particles.
                                       https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FPrinzip_vom_kleinsten_Zwang
               The principle of Le Chatelier , also called the principle of the smallest constraint , was formulated by Henry Le Chatelier and Ferdinand Braun between 1884 and 1888:
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FBose-Einstein-Kondensat
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FRaman-Streuung
                        " Leonid Almond stem" :P Correct : Leonid Mandelstam !
It does not translate : Albert Onestone  for Albert Einstein ,why then Mandelstam = EIGENNAME,EIGENWORT with " Almond stem" ?!
        http://www.rexresearch.com/platen/platen.htm
Einstein-Bose Kondensat : and von Platen works
3) A space engine that worked best at -273 degrees, rejected by the German Patent office because they said there was no such temperature ( 1925 or so ). Note the Nobel Prize in Physics awarded this week (10th October 2003).[/size]4) A near "perpetual motion " device based on the fact that he proved that very close to absolute zero, resistance disappeared. Again refer to this years Nobel prize winners.
                                      https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=baltzar+von+platen&CPC=&IC=&Submit=Search
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=1941644A&KC=A&FT=D&ND=3&date=19340102&DB=EPODOC&locale=en_EP
                                              to 2020 standart ? 8)
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=US&NR=1905660A&KC=A&FT=D&ND=3&date=19330425&DB=EPODOC&locale=en_EP
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=US&NR=1949504A&KC=A&FT=D&ND=3&date=19340306&DB=EPODOC&locale=en_EP
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=US&NR=1916240A&KC=A&FT=D&ND=3&date=19330704&DB=EPODOC&locale=en_EP
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=58&ND=3&adjacent=true&locale=en_EP&FT=D&date=19350508&CC=FR&NR=781021A&KC=A
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=63&ND=3&adjacent=true&locale=en_EP&FT=D&date=19310724&CC=FR&NR=708511A&KC=A
et cet.
        W =     F x s
onepower
David
QuoteIf you listen, talk, watch Eric Dollard's vids you would have realised by now the Electricatee syndicate has been generating the stuff and using resonance and selling zero pointy energy since the 60's
I have been following Dollar's work for decades however he uses almost unintelligible terminology and equations which only adds confusion to the subject in my opinion. I believe it was Einstein who implied... if we cannot explain something simply we probably don't understand it well enough. In this respect Dollar's master, Nikola Tesla truly was the master and often spoke conceptually in simple terms.
As well, I have worked in a power plant as have many of my Engineer friends and we can tell you as a fact your claim is questionable at best. I even designed and built my own island mode AC generators and grid tie systems. As such I would probably know if something shady was going on and there is not to my knowledge. If I may ask, what do you do for a living David?.
Are consumer paying much for electricity delivery ? Industrial B2B US electricity prices spread ,US B2C electricity prices spread ?
https://www.eia.gov/electricity/monthly/epm_table_grapher.php?t=epmt_5_6_a
New York,Industry : 5,4 US$cents !
