A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
kolbacict
How can this be?
We were kind of taught that a catalyst does not provide an energy gain.
The decomposition temperature can be lowered.The decomposition temperature can be lowered.
is not it ?
George1
Hi dear colleagues,
Thanks a lot for sharing of so many pieces of interesting technology information here. Need some time to consider everything carefully.
Quote from: Acca on March 19, 2021, 02:33:29 AM
So I here is my Hydrogen Oxygen Heater that I built from scrap parts, as the whole unit is made of aluminum to transfer heat to the outside.
It is filled with fish tank sand and Cordierite (crushed catalyst) about 2 inches on top...Need to heat up the cordierite with a flame torch to ignite the cordierite about 2 minutes. This heater consumes 150 watts of electrical energy and after about 30 minutes gets extremely hot so I reduce the voltage in to the HHO generator.. The COP is about 20 times and it is a (Low energy nuclear reaction) a level above chemical reaction. I will NOT debate on this topic period.. I will leave a link to a Korean company who has been in business now for 30 years doing HHO generators on the industrial scale now.. I am NOT talking small HHO kits... they use HHO gas to slice off 3 foot sections off steel like laser.. This is now in the major maturity market of HHO and still scientists have relegated this to a hobby and fringe science,, as European and US markets are still in the dark ages when to come to this technology..
Acca.. P.s.
Thanks to stupid western scientists who have never seen an implosion, and those that have seen it still consider that it is a condensation that cause the vacuum to form.. Look up LENR.. still fringe as power companies shun this topic.. Korea and China are in the energy spear of the future....NOT the West !!!
http://www.browngas.com/emain.htm
https://browngas.en.ec21.com/
http://www.csrf.ac.uk/2020/09/hydrogen-for-heating/
There You,Acca,will find the greatest followers and future ´hydrogen for heating ´ user !
Your delivered magnetvortex heater numbers  3000 Watt heat output by 150 electric Watts input changes the "blog calculations" !
demonstration and  scientifical (eastern or western ) Uni laboratory  input/output repeatable measurement would help ! ;)
Why not : Heriot-Watt Uni lab :
No discussion,measuring during operation ! ::)
Sincerely
OCWL
p.s.: high C.O.P. ?
        https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=de_EP&FT=D&date=20200514&CC=DE&NR=102018008797A1&KC=A1   C.O.P.: 10x
The aim of the development work is to save as much electrical energy as possible. Endurance tests prove that with the help of electrical energy, thermal energy in a ratio of 1 to 10 can be obtained with a saving effect of 90%! This established and verifiable performance opens up completely new avenues for the heating and hot water sector and could make storage an alternative technology to the combustion of fossil fuels such as gas and oil and could soon be part of the basic equipment of every house. Technical conception: The thermal conductivity of a liquid is the basis of the storage principle. Thermal energy by means of heat conduction in the form of heat in watts per Kelvin and meter is a temperature-dependent material constant. If current with a low voltage of 18-48 volts is passed through a specific liquid with two electrodes made of different materials, a potential difference arises. The flow speed of the positively charged photons increases many times over and thus leads to a temperature change in the memory.
The water temperature of 40-80 ° C reached is transferred to the domestic water to be heated in the storage tank and thus operates the heating system and water heater for the bathroom and kitchen. Main features: Polyfunctionality through two interconnected water tanks that realize the same radiator and hot water tank. The room air temperature is continuously regulated by thermostats. This process takes place silently and permanently, 24 hours a day. The domestic hot water temperature is also regulated. The high quality of the components, the low weight of the accumulator, and the ease of use and maintenance of the mechanical parts should be emphasized. The electrodes used are made of corrosion-resistant metals with a melting point of more than 800 ° C. The memory works permanently with a specified voltage and strength of the current, which is fed in either from the network or from a biometric volume
(photoelectric).
       sourced by Artificial (24/365) Photo-Voltaic generator  C.O.P.: 6- 12- 18 x
        sourced A.PV -lamps by
        magnetic generator  C.O.P. : 8x
        minimum  10 x 6 x 8 = high cascaded C.O.P ;  min. 400 up to near 1000
The " blog calculations" are easily to become " technical up to date"-d and corrected
Acca
I am back, I have posted some clips on YouTube as they deal with HHO subject and the excess energy generated by the HHO gas it is still quite interesting
puzzle still... I tend to "not believe" in theory only my method of  understanding that what I have done with the HHO gas and the energy that it carries is NOT one type of Hydrogen but multi-species of some heavy and lighter fractions based on what I have see by "doing my tests" I do not call these "experimants"..
https://www.youtube.com/watch?v=YfGIkH1C_ds&t=32s[/font]
I am drinking HHO water and will use it to breathe it next week as the Chinese have done with Covid9 patients, since the recovery is based on immune
response it seems the HHO at 4% or less may be the key to extending life for all people.. Now you have to understand the this gas is very dangerous, I am suspecting that there is a heavy form that may accumulate in voids like natural gas.. I cannot explain where this form is from, I seen that in an old book by Walter Russel he studied elements based on a "tonality" and in his diagram he has elements beyond hydrogen quite intriguing as he was a brilliant man..
That is all I have to say as this HHO research has come to an end for me, I am studying the work of Viktor Leonov..
https://vladimir-leonov.livejournal.com/12365.html
http://leonovcontent1000.blogspot.com/
  Dr. Vladimir Leonov is a Russian theoretical physicist, experimenter and inventor. In 1996 he discovered the quantum of space-time (quanton) and superstrong electromagnetic interaction (fifth force). He is the author of the theory of Superunification, holds a number of important patents in the region of new energy and space technologies and is the founder of quantum power engineering. He published more than 200 scientific articles and 6 monographs:`
1. Leonov V. S. Quantum Energetics. Volume 1. Theory of Superunification. Cambridge International Science Publishing, 2010, 745 pages.
2. V.S. Leonov. Quantum Energetics: Theory of Superunification. Viva Books, India, 2011, 732 pages.
At present, V. Leonov heads his own laboratory working on the development of a new direction in power engineering-quantum energetics. An experimental model of a quantum engine which underwent successful tests was developed for the first time. New results were also obtained in the area of cold synthesis in studies of quantum heat generators, etc. Dr. V. Leonov was awarded a Russian government prize in the area of science and technology and in 2007 was included in 100 leaders of science and technology of CIS countries.
