A SIMPLE ELECTRIC HEATER, WHICH HAS EFFICIENCY GREATER THAN 1
Started by George1, January 28, 2019, 02:58:40 AM
kolbacict
I wish him to eat this fish.
Came up with a way to measure the capacity of a Meer cell.
According to the Lissajous curve. I wonder if anyone has done this, or I am the first.  :)
At the same time, you can measure phase shifts, at different frequencies ...
George1
A really good discussion occurs here! Let me join it! :)
We (our multinational team) have created 11 (eleven) technology breakthroughs.
1) Please consider carefully and thoroughly the link below:
https://www.youtube.com/watch?v=aW2ffyvdhjk
2) The link above describes our first technology breakthrough.
3) The link above describes some simple experiments, which break (a) the law of conservation of mechanical energy and (b) the law of conservation of linear momentum. You can easily carry out these simple experiments in your garage as many times as you want. Any rule/law has its exceptions and there is nothing special, tragic and disturbing in this fact.
4) We (our multinational team) are open to collaboration of mutual benefit (a) for a further perfection and development of our technology breakthroughs and/or (b) for a  production of our technology breakthroughs on a large industrial scale.
5) We would like to ask you to popularize the link above as much as possible in internet (and anywhere else and in any possible way).
Let us push forward together the technology progress!
Looking forward to your answer.
Sincerely yours,
George1
George1
https://www.youtube.com/watch?v=xX14NK8GrDY
LET US PUSH FORWARD THE TECHNOLOGY PROGRESS!
Sincerely yours,
George1
kolbacict
video does not play. removed.
p.s. Does this forum have any topics about wind turbines?
p.p.s. The video has already appeared. sorry.
George1
The text below is a slightly modified, shortened and more precise version of our post of March 09, 2021, 02:46:35 PM.
Have a look again at the book "Solved Problems in Physics", 2004, Volume 2, p. 876, solved problem 12.97. The author of this book is Prof. S. L. Srivastava (Ph.D.)
The same book can be found at the link https://books.google.bg/books?id=rrKFzLB9KQ8C&pg=PA876&lpg=PA876&dq=%22electrochemical+equivalent+of+hydrogen%22&source=bl&ots=tQ8PSMLet3&sig=ACfU3U2HOLB78XHl2o3q-JanapzSK-McJA&hl=bg&sa=X&ved=2ahUKEwjDpp2-zZXhAhWT5OAKHUfuBzUQ6AEwBHoECAkQAQ#v=onepage&q=%22electrochemical%20equivalent%20of%20hydrogen%22&f=false
For your convenience I am giving below the text of the problem and its solution.
12.97. In the electrolysis of sulphuric acid solution, 100 mg of hydrogen is liberated in a period of 20 minutes. The resistance of the electrolyte is 0.5 Ohm. Calculate the power consumed. Electrochemical equivalent of hydrogen is 1.044 x 10 -8 kg/C.
SOLUTION.
Prof. S. L. Srivastava's solution is given below.
Prof. S. L. Srivastava's solution consists of two lines only.
LINE 1. Current through the electrolyte is given by I = (m)/(Z x t).
LINE 2. Power consumed = (I) x (I) x (R) =  ((m)/(Z x t)) x ((m)/(Z x t)) x (R) = 31.86 W.
Prof. S. L. Srivastava stops here his calculations.
(The related solution's set of equations is not given here in order to save time and space. This set of equations however can be found in the book or in the link above.)
WE DEVELOPED FURTHER PROF. SRIVASTAVA'S SOLVED PROBLEM IN A NON-STANDARD MANNER.
OUR FURTHER DEVELOPMENT OF PROF. SRIVASTAVA'S SOLVED PROBLEM LED TO COP > 1.
HERE IS THE ESSENCE OF OUR APPROACH.
1) Let us calculate the inlet energy, that is, inlet energy = (31.86 W) x (1200 s) = 38232 Ws = 38232 J.
2) The Joule's heat, generated in the process of electrolysis is given by
Q = (I) x (I) x (R) x (t) =  ((m)/(Z x t)) x ((m)/(Z x t)) x (R) x (t) = (31.86 W) x (1200 s) = 38232 Ws = 38232 J = outlet energy 1.
3) HHV of hydrogen is 142 000 000 J/kg. Therefore the heat H, generated by burning/exploding of 0.0001 kg of hydrogen, is given by
H = (HHV) x (m) = (142 000 000) x (0.0001) = 14200 J = outlet energy 2,
where
m = mass of the released hydrogen
HHV = higher heating value oh hydrogen
4) Therefore we can write down the equalities:
4A) outlet energy 1 + outlet energy 2 = 38232 J + 14200 J = 52432 J
4B) inlet energy = 38232 J.
5) Therefore COP is given by
COP = 52432 J/38232 J = 1.37 <=> COP = 1.37 <=> COP > 1.
IMPORTANT NOTE. Constant pure water and cooling agent supply could keep constant the electrolyte's temperature, heat exchange, mass and ohmic resistance, respectively. Besides 0.0001 kg of hydrogen (and the related amount of the already split pure water) is small enough and can be neglected as a factor influencing the electrolyte's temperature, mass and ohmic resisitance.
And one more interesting fact.
Literally the same solved problem can be found in an old Russian (still from the Soviet times) book "Сборник задач и вопросов по физике", 1986, p. 130, solved example problem 71. The authors of this book are Р. А. Гладкова and Н. И. Кутиловская. In the Russian version the data is a little different, that is, time is 25 minutes, the amount of generated hydrogen is 150 mg, Ohmic resisitance is 0.4 Ohm and the calculated power is 37 W.
Russians also stopped their calculations at 37 W.
Our further development of the Russian version led to the same COP = 1.37, that is, we have again the same COP > 1.
