Free energy as simple as it gets
Started by indigo22, April 01, 2022, 08:05:54 PM
MagnaProp
I have no idea why the water turned blue but it's good to see that work is continuing here.
What did Nikola tesla use for diodes in his day? The Ronald Brandt circuit and lots of others shows diodes but it just got me thinking of what Nikola would have used?
captainpecan
Quote from: MagnaProp on April 24, 2022, 04:49:10 AM
That's a good question. I'm not really even sure Nikola Tesla was ever involved in this circuit or if it just inherited his name. All I have to go on is the very little out there to read about it.
But, the diode was invented in 1904, so he did have access to them. He also probably used vacuum tubes. But, as far as if he actually worked with this circuitry concept, he probably would have just used contacts for switches. The diodes are not needed for it to work. Just makes its easier for switching and to help make sure you don't short out a battery. But if the diode wasn't used, just a series to parallel switch system would do it. The potential difference it runs on will be going only one way anyway. From higher voltage to lower voltage source. Just thoughts. Back many years ago when I was playing with this, some of us where just using the shaft of the motor we were running to turn discs that made the contacts switching the batteries the ran the motor to begin with. Would get pretty sparky. I played with all kinds of things trying to snag extra energy from all that. I was never successful, but it sire did recycle a portion to use over and over. In a way, that is technically free energy since it was being thrown away before. But I didn't match some of the great claims. For me, it was just a great way to get more run time.
captainpecan
Quote from: FreeEnergy on April 23, 2022, 10:08:05 PM
I'm not sure why the saltwater turned aqua-blue-ish?
Maybe you accidentally electrocuted and melted a smurf while you were sleeping!!! Lol...
On a serious note, since I am unfamiliar with your battery, I did a bit of hunting to learn more. And I found one that changes colors as it charges. This one says it literally charges in seconds also. That sounds pretty damn interesting. Could your color be the same effect?
https://www.imperial.ac.uk/news/190596/non-toxic-salt-water-battery-prototype-charge/amp/
FreeEnergy
Update:
I'm using a 12v Deep Cycle Marine/RV Battery.
I used 15 ounces of epsom salt per 1 gallon of distilled water.
Dissolved epsom salt over the stove, used a small pan then mixed back with the rest of the gallon used.
So in my case I'm using 3 gallons of distilled water and 45 ounces of epsom salt. Copper plate goes to (+) and aluminum goes (-). Wait for (a few days?) the settlement at the bottom creating a layer. Scoop out the saltwater from top, the bottom layer should be your "plasma fuel".
This is what I understand and what I'm doing, hopefully it works.
e2matrix
Update:
So I moved on to the "plasma" cell/battery that Peenie Wallie talks about in one of his videos.
Likely Copper Chloride which is aqua / bluish since you have copper and sodium chloride (salt) in there.
