Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Ufopolitics
Quote from: pix on June 04, 2022, 02:01:40 PM
At the end, it is your time and your money wasted. ;)
Good luck.
Pix
Thks Pix, yes, you are right, it is my money and my time...
But what "if"...it works...what would you do "if" I show everyone O.U. on my build?
Would you replicate it?...or you would just start denying it and Nahing it?
Just asking...
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
SolarLab
Ufopolitics,
You do some excellent work - thanks for sharing! You will, most certainly, achieve your objectives IMHO.
Over the past couple of months, as you might be aware, the Holcomb methods and techniques, in the form
of a pseudo Linear Generator (LinGen), have been studied by way of advanced Computer Aided Engineering (CAE).
Results of that analysis strongly indicate:
1. A magnetic field can be made to move, or slide (rotate), along a metal structure by way of only using
electical pulsing of Pole Coil/Windings. There are no moving parts if the pulses are created electronically
(as shown in the patent).
2. The magnetic field can be "amplified" or increased by way of using ferromagnetic metals for the
Pole pieces. This follows, to a great extent, the well known material BH Curve. It appears to perform
somewhat differently to what is commonly published, but the phenomenum is clearly present.
3. CAE output data strongly points to Excess Energy output as compared to standard generator
performance (as claimed in the patents).
CAE analysis is found in a series of posts in the OUR Forum under "Solarlab," with the brief final results starting at:
https://www.overunityresearch.com/index.php?topic=4261.msg99112#msg99112
Of interest are the "Co-Energy_Energy" and "Induced_Voltage_Coil-9" (the output Lap Wound Stator coil)
graphs [attached].Unfortunately only two cycles (16mSec -> took about 8 hours of processing) were simulated but the trend
line of the Co-Energy graph is quite enlightening.
A related, but off-topic subject here [soon to be investigated and published], focuses on the driver pulse
generation using electronic means (inexpensive microprocessor driving high speed SiC or GaN FETS) with
flow chart derived software - easily modified as required.
Again, great work and best wishes!
SL
Graphs are too large, sorry - will have to figure out how to reduce them.... stand-by?
Ufopolitics
Quote from: SolarLab on June 06, 2022, 11:35:37 AM
Ufopolitics,
Thanks much SolarLab,
Greatly appreciated, basically when coming from someone like You!!
I also admire your work, you do incredible research and developments, and deep analysis and graphics.
Yes, it should work, and will work...previous studies and experiments show very promising results.
Best regards
Ufopolitics
―Leonardo da Vinci
rakarskiy
I want to inform you that the Holcomb system, like any other solid-state electromagnetic generator, including a synchronous electromechanical one, where the stator has slots, operates on a speed change system. The speed, paradoxically, is magnetic induction.
Magnetic induction is measured in Tesla and Gauss: 1 T = 1 volt per second per square meter, and 1 gauss = 0.0001 volt per second per square meter.
https://en.wikipedia.org/wiki/Magnetic_flux
I do not think that many will understand me, but today I nevertheless solved this problem. How simply the materialists have translated everything into material forces. But even two magnets is an interaction of fields. and the two bodies of the magnet attraction and repulsion is a consequence of the work of the fields.
The plate in the attachment, when borrowed from an alternative forum from Russian-speaking physicists. This is a comparison of two systems electromagnetic and mechanical. Only the spin permeability of vacuum (mechanics, gravity) remained unclear. A very tricky moment, similar to voltage in electromagnetism; In mechanics, speed works. And the capacitance of an electric capacitor is the charge (charge capacity) divided by the voltage (we read the speed).
Next, we draw a conclusion about the mechanism of electromagnetic induction, and another type of hidden induction, on which other solid-state devices probably work (Kapanadze, S. Mark ..)
SolarLab
rakarskiy,
Your "solution" linking material forces, magnetics, and electromagnetics appears, for me at least, to be quite brilliant!
A "speed" or velocity element [squared] is found in nearly every system, and the equations used to describe them
[per second per square meter].
To quote, in part, from your writings (this is worth repeating in my opinion):
"In mechanics, speed works. And the capaticance of an electric capacitor is the charge (charge capacity)
divided by the voltage (we read the speed)."  [dx/dt]   "Next, we draw a conclusion about the mechanism
probably work (Kapanadze, S Mark ..)"
Linking "electromagnetic and mechanical" systems via "spin permeability of vacuum" is indeed a "very tricky moment."
A while back High Voltage was linked to the operation of devices similar to Kapanadze, Ruslan and Stalker but a detailed
physics connection was vague at best. Ref:
https://www.overunityresearch.com/index.php?PHPSESSID=tkjqdoee4vq0ppjto421pt59q6&topic=4154.msg96356#msg96356
Your conclusion may well be that missing link.
This video might also be of interest:
https://www.youtube.com/watch?v=B0BOpiMQXQA
Thanks for sharing your insight and best regards,
SL
