Resonance and HHO
Started by pauldude000, February 01, 2013, 06:14:06 AM
kolbacict
https://en.wikipedia.org/wiki/Double_layer_(surface_science)
In this layer achieves the highest electric field strength, due to its small thickness, of all possible in water, right?
kajunbee
https://arxiv.org/pdf/1611.04677.pdf
But they did not succeed in water splitting by high electric field only.
pauldude000
They are still basing their system off of a pure constant DC source -- standard electrolysis -- but applied at the micro scale. Standard electrolysis is inefficient for numerous reasons, but a common one is the collection and pooling of negative ions reducing field strength. You have to dump massive amperage to get anywhere.
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
kolbacict
Quote from: pauldude000 on May 04, 2022, 01:29:33 AM
In anyway the double electric layer is very slim.  Therefore it is small volume.
it cannot produce much gas. Am I right?
alan
resonance of water is in the ghz range (Kanzius iirc), you need resonance for a VIC to crank up voltage while blocking amps through mutual inductance.
