Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Ufopolitics
Quote from: bistander on October 26, 2022, 04:51:16 PM
Hi Ufo,
I hear you, but don't agree that your analogy applies. Like, how much space is 2 volts compared to 5 volts?
Hi Bi,
Space is defined by x,y,z 3D axis, as is also Volumen.
Yes, there is a difference in a Field generated by 2V versus a 5V...it is easy to see it with any magnetic viewing film, in ANY angle you see it around the generating coil or PM.
The Magnetic Field is propagated beyond (in Space) of the coil/core or PM embodiment which generates it.
edit: Ufo, do you still believe that magnetic flux flows? That may be an issue.
I am not going to start a debate here, about the way I see "flux"...
I will just leave you here, the meaning of the word "flux" as first hit whenever you search it on Google.
Flux: 1- the action or process of flowing or flowing out.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
bistander
Quote from: Ufopolitics on October 27, 2022, 08:10:53 AM
Hi Bi,
<snip>
Cheers
Ufopolitics
Hi Ufo,
Yes. No need for you and I to go around on this again. But for other readers, it is incorrect to Google "flux". Need to find proper definition of "magnetic flux". "Magnetic flux" is not "flux".
bi
NickZ
Quote from: bistander on October 27, 2022, 08:59:34 AM
Hi Ufo,
bi
   bi:  IF magnetic flux is not flux, then what is it? I am one of the "others", and I'm all ears.
   Magnetic flux, by wikipedia: https://en.wikipedia.org/wiki/Magnetic_flux
   Perhaps the above definition, needs a more proper definition, or not?
   NickZ
bistander
Quote from: NickZ on October 27, 2022, 09:30:58 AM
    Thanks,
    NickZ
   P.S.  Magnetic flux, by wikipedia: https://en.wikipedia.org/wiki/Magnetic_flux
Hi NickZ,
"Flux describes any effect that appears to pass or travel (whether it actually moves or not) through a surface or substance. Flux is a concept in applied mathematics and vector calculus which has many applications to physics."
From the first link at the end of the article that you referenced.
You can certainly find better definitions/explanations of magnetism and magnetic flux than what I can post. I do recall article(s) stating that historically it was a mistake to call or refer to magnetism as "flux" and it was due to misconceptions of early researchers/scientists, but the errant term has stuck to this day. Unfortunately.
bi
NickZ
Quote from: bistander on October 27, 2022, 09:59:26 AM
Hi NickZ,
bi
   bi:  Thanks for the clarification.
   The idea that "magnetic flux", may not actually travel, is worth looking into. As it may be the secret behind free energy, and Open Systems, without draining any input source.
    So called Sun Light, also, does not actually travel or move as we know it, there is nothing traveling, any more than a wave in the ocean, does not travel, either.   Nor is so called "Sunlight" actually created by the Sun, and then "travels" to Earth. What we call Sunlight, is created on Earth, but is polarized by the Sun, instead.   I know that most of you may not agree, that's ok, I know that it's not what we've been told, but, just remember about what I said about sunlight, magnetism, and even gravity, not "traveling", nor "moving"  Some of you will "get it". Even though most of you will not. I expect that, as well.
    The idea is to not kill the dipole, nor to expect a gain from energy "traveling". That is, only, if free energy is the idea...
    As cosmic flux, of the "cosmic soup", or Aether harvesting, is what I'm after.  As was mentioned by Tesla.
     NickZ
