Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
SolarLab
Did you happen to find out anything on the "one-way bearings" mentioned in the patent disclosure?
One-way Bearing  (from the patent disclosure)
At 7 line 32 thru 44 "one way" bearings are briefly discussed:
Note that during the rotation of the control shaft there is interaction with the output shaft which has the armature with the permanent magnets attached and both the control shaft and output shaft may try and turn the other in a different direction than desired. That is, for example, as the control shaft rotates in a given direction the output shaft may try and rotate it in the opposite direction (i.e. backwards). In one embodiment, the control shaft cannot be forced backwards by the output shaft if one-way bearings hold the control shaft. Likewise, in one embodiment, one-way bearings may be used to hold the output shaft so that it can only rotate in one direction. In one embodiment, the control shaft and the output shaft are each held by one-way bearings.
Further - At 7 line 45 thru 60:
In the specification and figures the control shaft as noted has attached to it the radial field control, this control shaft may be rotated, for example, by a motor or other rotating mechanism. What is to be appreciated is that the control shaft having the radial field control is able to control the armature rotating within a magnetic circuit. The magnetic circuit comprises the radial field control the armature having permanent magnets and the stator. The output shaft which is connected to the armature can rotate (assuming it is not overloaded or locked) and this rotary motion can be used. Thus, the input control shaft can control the output shaft.
While the description has shown two permanent magnets as part of the armature the invention is not so limited and any arrangement of magnets on the armature that yields a magnetic flux passing through the radial field control and
stator can be used.
stivep
Cigaret Lighter indicates 12V
look at the picture.I'll find more about it
but  pictures are self explanatory
So now our list of  motor models is much shorter
I spend   1 day to find everything you didn't find yet
- measuring   apparatus   model  and manufacturer
- speed control  model    and manufacturer
- motor  used  model      and manufacturer
- list of motors and specification  model  and manufacturer
- power supply model  and manufacturer
Please do me a favor guys:
just read it from here will you ? :
Re: Magnetic flux motor just patented that creates it's own electricity!  « Reply #129 on: March 07, 2023, 09:09:11 PM »
opinion expressed is my own
Wesley
stivep
For Non English audience I repeat text is on the picture :
Motor model is  established now based on  used by inventor  Power supply/ we know speed and torque.
But interesting is that  the same  motor driving inventor device shown in two  different  instances in the same video shows:
motor IN at its 51 RPM speed shows 0.7 ft-lb
motor IN at its 33 RPM speed shows 0.1 ft-lb
while  inventor is trying to prove  gain of the device :)
___________________________________________________________________________
The inventor claim of more  energy OUT than IN
and  surprising evidence on measuring  equipment
was analyzed by me:
So look at picture and in video  and it is :
up to you  to   conclude :)
https://youtu.be/_gGLN2LxwkY?t=133
Wesley
stivep
Please look at  below showing two different
time frame  pictures in the same video and look at:
connector connection to the measuring device
But this is not all:
Please also look at time on the video showing measurement IN
and compare it with   IN - picture from up there  in the previous post  from the same video.
Look at measurement numbers too.
Wesley
