I need help with a KEELY project
Started by hansvonlieven, September 20, 2007, 05:30:42 PM
Localjoe
I feel everyone should read this
http://www.soulsofdistortion.nl/SODA_chapter5.html
Greek philosopher Pythagoras discovered a wonderful mathematical relation between the harmonic notes in music. He noticed that by depressing a string in different positions on the fingerboard of a guitar like string instrument that harmonic sounds were created. Some notes sounded better than others. At each depression of the string the string is divided in two different lengths and the ratio between these lengths were measured by Pythagoras. He marked down all the ratios that sounded harmonically well together. In this way he found the following ratios:
1:1 (open snare)
1:2 (depressed at 1/3 of the length of the string)
3:2 , 5:3,  13:8,  21:13, 34:21
What Pythagoras had discovered is called the Diatonic musical scale, named after the fact that the string is divided into two lengths (Dia = two).
These ratios correspond with the frequencies of the notes produced by the white keys of the piano when attuned in the Diatonic scale. After the 7th note the octave of 8 notes is repeated only this time the first and the eighth note are doubled in frequency! The next 7 notes of the white keys on the piano follow the exact same ratio!
Now if you have been paying attention you may already have noticed that the musical ratios discovered by Pythagoras are the same ratios of the Fibonacci sequence! Simply take a number out of the Fibonacci sequence and its successor and you have the musical ratio found by Pythagoras.
The Fibonacci sequence is the sequence that gives us beautiful harmonics in music. The diatonic scale is not the only musical scale, there are many more, in fact no piano today is tuned in the Diatonic scale. But the principle relation between harmonics in music and mathematical progressions of the Fibonacci sequence is real.
Now let?s pretend that we?ve tuned a piano in the Diatonic scale and that we have extended the piano?s keyboard with keys to provide for 49 octaves! That would be one hell of a piano and it would certainly no longer fit into your living room!
But suppose that we could actually play on this piano. When we play the notes in the last two highest octaves, the keys on the furthermost right side of this piano, will correspond with the frequencies of the colours of light!
There are seven keys in the highest octave that are the frequencies of the 7 primary colours of the spectrum of light, the 7 colours of the rainbow!
So not only does the Fibonacci sequence define the ratios of harmonics in sound but also in the electromagnetic spectrum of light, it defines the 7 colours of the rainbow!
Music and color, the same harmonic ratios
We now know that many musicians like Beethoven, Mozart, Chopin, Bart?k, Schubert and Debussy used the Fibonacci sequence and the Golden Mean ratio deliberately not in the notes but in the composition itself. For instance Beethoven used the Golden Mean in his famous Beethoven?s Fifth. His famous opening motto not only appears on the first and the last bar of the symphony but also on the bar that represents the exact Golden Mean point of his symphony! Bela Bart?k used both the Golden Mean and the Fibonacci sequence deliberately in his compositions using the measures 5, 8, 13, 21, 34, 55 and 89 to introduce new instruments such as strings, cellos, percussion etc.
After reading this one I believe youve stumbled upon something much bigger than i initially thought and it defiantly proves Keely wasn't a con artist to any nonbelievers out there still..... He was in the know of this sacred geometry and used it in his work
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
Im simply blown away by the implications of these findings and the parallels between this Keely work giant killers tpu and the rodin coil theory azerzw has talked about everyone should digest these 3 pieces of data I've posted in the associated forums it wold benefit many people here .
giantkiller
Quote from: Localjoe on November 03, 2007, 08:25:41 PM
Yep. I was blown away when Hans posted the Keely site. Talk about the Holy Grail dropping in your lap! That is why I built the Keely generator so damn fast, with the Bucket-o-vibes, The Bose Acoustic radiator standing wave, and had IS do the 3 speaker heterodyning. There was no experimenting here. Just turn these things on and get garanteed phenomimal results! Like pluging in a microwave oven! And even now I have a fantastic piece of equipment on my bench that reaches far into the past and future for testing. It's amazing. It is like having an o-scope 100 years ago.
--giantkiller. Thanks for the reference.
fritz
Quote from: hansvonlieven on November 03, 2007, 01:21:53 AM
I don't get it Joe,
This is just a circle of fifths arranged repetitively along a spiral. It doesn't make sense musically. I would like to know where you found this arrangement and what it is supposed to mean.
Hans von Lieven
Dear Hans,
I think this and similar stuff is used to damp certain frequencies (unwanted ones,
unwanted harmonics).
If you have point A oscillating with frequency a,b,c,d,e,f,g - and you want just
frequency c has his maximum amplitude there -  you put such thing on with rods
tuned to frequencies a,b,d,e,f,g.
"schwingungstilger" is the proper name in german - dont know how to call that in english.
Its like suck up unwanted frequencies by using a series lc in electronics tuned to
the unwanted frequency.
In some keely setups - I think similar stuff is used at the feedpoints of the resonators -
to select which frequency of the compound wave on the wire feeds the actual resonator.
Anyway, have seen lots of photos of your webpage - I think these are "passive" components -
and not used to be excited manually or whatever.
rgds,
Wolfgang
fritz
Some speculative thoughts :
If I want to build a "3 phase" "keely motor" operated
by 3 frequencies - I would choose 3 complete
independent frequencies based on primes -
3,5,7,11....
By feeding the frequnencies in series 3 - 5 - 7 -
and hook up a "filter" which filters 5,7 out for the
phase 1 resonator, 7,3 out for the 2nd resonator -
and 7,3 out for the 3rd - connect everything with the "wire".
By playing 3(on the wire) - I can excite p1, playing 5, excites p2 ....
... operating a motor by playing a triole .....
just speculation.
Thats frequency multiplexed controlling -
crazy musician.
Same principles - different technology (unique).
