Pulse Motors- Your building them wrong.
Started by tinman, August 30, 2023, 12:55:41 PM
tinman
Quoteauthor=Kapalek link=topic=19546.msg581892#msg581892 date=1693596745
QuoteI would like to join the project however I am not sure If I would be able to keep the necessary quality of my model.
I wish everybody luck with the project.
Just give it a try.
You can only do your best.
QuoteI really think that Inverted realities channel is the best channel on the topic and probably everyone here will agree.
Yea, he seems to know a bit about the topic  ;D ;D ;D
Brad
tinman
Just so as every one knows, below is a pic of what we will be referring to as the gate.
If you remove one of the PMs, and replace it with a coil, this is what we will have.
The torque plates will be passing through this gate.
You will need to put aside the normal understanding of how things should be set up for this build.
One would think that the gate should be made from having a south field on one side, and a north field on the other, in order to obtain maximum pull force. But this simply is not true. When using two like poles facing each other, the field produced will not be the sum of the two fields, but in excess of 3 times the field strength.
I will have a video up before the days end, showing the test process.
Brad
tinman
Here is a video to show you how to match your coil to your permanent magnet, and set up your test bed.
Also shows the difference between a standard pulse motors torque, to that of the torque force motor.
Next video will show you the torque curve difference between a standard pulse motor, and the torque force motor.
https://www.youtube.com/watch?v=s3UZ-BZoq-A
tinman
Here is a jpeg of the graph you can print out in relation to the next series of tests you will need to carry out, in relation to the next video.
Brad
tinman
At this point, i would like to say-make sure you watch all video's in order, and carry out the needed tests.
This test is a must, as it will give you a base line.
From this base line, you can make small changes, and compare those changes to your base line.
This way, you will know if you are going in the right direction, or the wrong direction.
This will also show you that this unconventional motor design, far exceeds that of the normal designed motor.
https://www.youtube.com/watch?v=QwbP4b4tlFU
Brad
