Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
@scorpio
no it is not a mistake. They ARE shorted. The battery on the right is NOT connected. I draw it to show how the original schematics (that you can see on the video or here http://www.esmhome.org/library/john-bedini/report_on_4_battery_switch.pdf (goto page 11) (also on another post http://www.overunity.com/index.php?topic=3160.msg46339) is designed.
Simply I removed the second battery and I am using the source battery as the destination battery too. It is just a proof of concept of the whole 4 tesla switch design.
And the reason for the LEDs on the right and the resistor is because by working on it I came up with this impedance matching (at least somehow - monkey science  ;D) would allow the battery to charge itself up.
Fausto.
BEP
@Plengo,
It seems you are doing very good work!
What happens if you disconnect the transistor base? The reason for my question is:
1. Like said before a diode can act as a varactor under certain circumstances.
2. No base connection or next to nothing on the base may allow NRO action (negative resistance oscillator)
Thanks,
bep
Silvije
plengo
@BEP
thanks.
QuoteWhat happens if you disconnect the transistor base?
No current, no light and no drop in voltage or increase on the battery.
I tested today under a power load computerized device and interesting is that it showed that frequently there is an opposite current in order of .1ma returning to the battery. I would say about once per second.
Fausto.
scorpio
@plengo
It is very interest and strange. I try build this...
scorpio
