Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
@hakware
this one is the old schematic with the mosfet. But this has two circuits one connected to the other so that one feeds the other back instead of having two separate circuits. I dont want to give more details until tomorow after it is running for the whole night. I have to make sure voltages will not go down after 24 hours than I will be pleased to help others without misleading anyone.
But because I am not perfect, I just wanted to give some pics up so to keep everyone "inspired" to do good work.  ;D
And since I am here posting. I noticed that the new design has exactly the same level of luminescence of my succesfull first circuit. If I play with it I can make it go very, very bright, but than voltage goes down. So I have to find the best spot and it has some correlation.
Fausto.
hakware
@plengo
Sure, I understand. I will look forward to your upcoming data.
Bruce_TPU
@ Fausto
I hope that you have very good news in the morning.  I look forward to trying your circuit as well.  Fooling with these batteries, now for 2 days, I am worried about the amperage.  I have seen in these new ones, that the volts can go up, but there is very little amperage.  Enough to keep the LED's lit, but for how long, is the question, for you and me.  That is why I continue to test for amperage, not just reading the volt level.
Also, with these new batteries, they do recover, very quickly, in voltage reading.  I drained my newest battery to .45 volts and it recovered in voltage by itself to 5 volts and climbing in 10 minutes.  I then put it back onto the 30 ohm resistor to drain it some more.  Just by themselves, these are incredible batteries.  But, let me add, that the 5volt reading, had very, very little amperage.  Not even enough to start my mini motor.  I am encouraged that you have been running the LED's all of this time.  I would suggest taking a volt and amp reading of each LED and multiplying that by LED's and hours run.  These batteries are rated  at 150ma @ 8.4 volts.  This is 1.26 watts.  I think we would all be interested to see those numbers, if you would be kind enough.  I can not do that with mine, because of the on/off of the LED's.  It becomes a guessing game.
@ All
The battery I drained with the mini motor, went up to 7.02 volts.  This charged much quicker then last night.  I have removed all but 1 LED.  The flashing LED's look cool, but are useless.  Unlike steady on LED's, that can be used for a flash light, etc.  The goal is to have the battery self charge.  And now there is more power for that...I hope.   ;)
When the battery reached 7.02 volts, I disconnected it and hooked it to the motor and it ran for about 20 seconds and then died.  I then have reconnected it to the oscillator and am letting it charge (I hope) up again.  I just need to be convinced this is not the batteries.  These batteries are incredible by themselves.
Holiday Cheers,
Bruce
plengo
@btentzer
you are absolutely right about this batteries. That's why in this new test I am doing I connected 40 LEDs so it MUST drain the hell of the batteries. My older test is still running pretty good. Now at 8.13v and LEDs are bright as when I started. I will run more tests where I will hide this things under somewhere far away from any interferance of any kind so that I will be 100% sure it is not radio waves or something like that feeding the circuit. One test at the time.
I already see this new circuit drainning down very fast the batteries but lets see where it will stop by tomorow morning. The same happened with my good running baby. It went down to 3.5v then slowly climbed back to 8.13v.
My last measurement of current in one LED was about 5ma. I have 40 in parallel. So I am really pushing this guys. I can also see already that the big coil is a huge factor here. I dont know why but it is leading me to believe that.
Fausto.
ps: video at http://www.youtube.com/watch?v=-3DsUTpdnDM
AbbaRue
What I would like to know is the Inductance of the 2 windings.
If we know how many Henrys the coils are we could try duplication them with smaller coils.
You are using air core coils, how would ferrite cores work.
The coils would be a lot smaller for the same inductance.
The core of an old flyback transformer could be used.
