Some thoughts on how the TPU might work.
Started by dfro, November 26, 2007, 07:43:29 PM
EMdevices
In the UEC video towards the end, and speaking about the little toroid,  SM made a few points:
1)  The device is NO LONGER dependent on the orientation relative to the earth
2)  The device:  ".. it is not over unity... not something magical. and in fact it uses common everyday principles.. .... the  the  use of a magnetic field... the use of magnetism.. to cause electron motion in a wire...it's something we use everyday..."
I would debate him on one thing only  "OVERUNITY"    Ha  Ha  :D
So what does it mean?  Well,  if you read his letters he describes the principles and they all require ACTIVE  components to DRIVE IT, but he does say he learned how to start it with just ..."a swipe of the magnet"  Those must be the small units totally PASSIVE I imagine.
EM
Grumpy
        -Frank Edwards
Grumpy
The magic is in knowing what "electricty" is and what a "current" is.
        -Frank Edwards
wattsup
@EM
Your point No.2 in your last post says it all and touches upon a post I made recently located here:
http://www.overunity.com/index.php/topic,3779.msg65838.html#msg65838
The TPU is a glorified transformer. Transformers need a primary, an armature/core and one or more secondaries.
Primary is the control coil, armature/core is the bailing wire ring. Now here's where it varies. In the midst of a magnetic field, if you have the right type of wire and it receives a simple audio frequency, it will vibrate. So if you wind a coil over the bailing wire ring in such a way as to enable vibration, and if this coil has two or three individual conductors with frequency going to only one of them, then all three will vibrate together inside a magnetic field and the two other wires will produce energy. Now since you are creating a mag field that will not be 100% used for the coil vibration, you wind another coil over this to recapture the mag field in order to re-cycle the energy used to make the field in the first place.
Now since you have a bailing wire core that can hold a field, it may not be exposed to the normal eddy currents plus this permits you to pulse energy into the primary and while the pulse is off the bailing wire still holds the field. Tesla did this all the time in his patents whenever he used a rotating contact. So by pulsing the primary, you are using the least amount of energy to build the field, and with the third coil over everything else, you are catching the energy from the mag field to put it back into the loop (like a secondary). These two actions have to be the least energy consuming as possible.
If you took a regular transformer and wrapped a coil over the armature, you will catch energy that would have been otherwise wasted or not transfered to the secondaries. But there has to be an armature or core since this is the medium used or required to transfer and recapture the energy. Trying to do this wire to wire is very difficult and in my opinion, will not reach any level of efficiency to work in an OU system.
In the above case, SMs' magnet over wire analogy would happen twice. The mag field is pulsed so it is moving over a wire, and the wire is vibrating, so it is moving in a field. A double wammo effect.
Grumpy
transformer?
Holy Crap! This ship is sinkin' fast!
Have you ever heard of a ransformer that ran with "gain"?  No! and you never will.
        -Frank Edwards
