Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
otto
Hello all,
its Sunday early in the morning and Im sitting in front of my PC.
I thought the people would hang me because of my little theory but not 1 word about it.
Do you think that the little dirty worker from the little country doesnt know what he describes??
Just to tell you a little secret: on Friday I made a little demonstration of the 3stack TPU. I was with a top scientist and his team.
It was veeery nice. Guess what they saw.
@MCD
I hope that I understand what you want to say but as I have a "photo memory" I would prefer a drawing.
Otto
Motorcoach1
Otto nice to see your work. I agree with you on the slow down ,I have found this on the tubeing (small copper tube ) that the positive flow is on the inside and the skin effect is on the out side so the speed is easly regulated. I would have prefered useing silver tube to test with. on the larger aluminum tube set up I have I put the capasitors inside the tubeing ends. good luck Mike
otto
Hello all,
in the picture that I hope to present are shown the connections of the 3 stack TPU as I did it.
In the picture you cant see caps because I have NOT the equipment to measure the inductance.......I cant in this moment make resonant circuits.
Here you have it:
top collector - 9 turns - lamp wire
middle collector - 5 turns - lamp wire
bottom collector - 3 turns - lamp wire
All controls wound all over the circumference - 57 turns EACH - wire diameter 0,35mm
2 feedback coils wound over everything and all around the circumference - 256 turns - 0,5mm wire diameter
You dont see a connection from the power supply because its on you to see wrer the best connection point is!!
Dont ask me how and why. Its only a feeling because, as I said, I dont have the needed equipment to make the coils resonant.
More will follow.
Otto
otto
Hello all,
bravo Otto, ha,ha ,I did it! I mean, I have always troubles with posting pictures.
Now the little secret:
You know  that Im following "dfros" 2 posts.
He said something about a BATTERY and rising the voltage. I did it without the battery. I rised the voltage from my power supply.
Im always working with 24VDC (fact is that I have only 18VDC) from my PS and I rised the voltage to 30V. Carefully changed the frequencies, rised the voltage to 35V, tuned again the frequencies, rised the voltage to 40V and something started.....
Guys, this is NOT anymore TPU KINDERGARDEN.
Working in this way will blow you from your chairs and the s..t out of you!!!!!
Your equipment will be destroyed if you dont have a kill switch!!!!
You will for sure be killed if you touch the fucking wires!!!!
What exactly started is on you to show us all, I saw it.
If you work in this way and with the 3 stack it would be clever if you use 2 100W bulbs as load. I hope such a little load is enough, or not? Hmmm...
In my schematic you can see that Im feeding all the power back. THIS IS WRONG. Please dont teach me about coils and feedbacks because Im in this job for almost 2 years. I know of course that I have to feed back only a tini bit....
Teach me how to control this f...g beast.
GUYS I LOVE YOU ALL AND PLEASE, PLEASE IF SOMEBODY IS CRAZY ENOUGH TO DO WHAT I HAVE DONE BE CAREFUL!!! Yes, I know, you have expirience but this is something else.
Otto
