Working Magnetic Motor on you tube??
Started by Craigy, January 04, 2008, 04:11:39 PM
blue_energy
Quote...so 258 grams seems somewhat confirmed.
Oh!  And someone later points out (can't remember who - sorry) that the rotor weight can't be right for this calculation because it isn't considering the weight of the magnets.
<Edit Much Later>
I found this just now from Al on Jan. 6th on the Whipmag development discussion:
QuoteMass of rotor assembly, including magnets and shaft adapter, but not including shaft or bearings:
258 grams
Mass of stator magnet assembly, including holder, magnet, and bearing:
10 grams. Variation between the 13 units is below the resolution of my (home) scale.
...so, the comment about the 258 grams not including the magnets was incorrect.
Craigy
I believe the wieght of the stator was 10 grams, the magnet is 5 , so combined wieght of bearing and holder would be just over 5. I say just over because the inner portion of the bearing does not move
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
geodan
Quote from: Smit80 on January 17, 2008, 12:57:18 PM
That would be Behind Enemy Lines ...
Found here:
http://www.hotmoviesale.com/dvds/6659/1/Behind-Enemy-Lines.jpg
maybe someone could post a picture of a ruler on the DVD? might give us a little more perspective here and there...
Jinis
CLaNZeR nice engineering work!! If the distance to the rotor playes the role here (see attached)? It is bigger that on ALs device??
hydrocontrol
It appears to be slightly different camera angles. Al's is off to the side while CLaNZeR is straight down.
This would make it appear that Al's stator is closer to the rotor than it really is.
Quote from: Jinis on January 17, 2008, 01:54:16 PM
