Working Magnetic Motor on you tube??
Started by Craigy, January 04, 2008, 04:11:39 PM
0 Members and 62 Guests are viewing this topic.
Yadaraf
Quote from: Omnibus on February 08, 2008, 06:12:53 PM
@Yadaraf, @blue_energy and @MeggerMan,
This is a sound sample of my rig with only stator rotating gear wise. I span the rotor by hand as uniformly as I could to keep it at 259rpm (monitored by a laser tachometer). As you can imagine maintaining by hand a constant rpm isn't easy so it fluctuated between values some reaching 280rpm. Nevertheless, it may probably be interesting to see what this will look like in the frequency domain anhd if the recent discussion can explain the fundamental frequencies observed.
Omni,
Is there a chance you can try this again?  The audio is faint and I can't tell what's happening at the low frequencies (i.e. the signal-to-noise ratio is very low).
Q1:  Could you increase the volume by moving closer to the device?
Q2:  Could you provide a baseline at the end -- leave the recorder on for a few seconds and stop the spinning.
My new software allows me capture a baseline spectra and then subtract it from newly acquired spectra.  A good baseline (no spinning, no voice .. quiet as possible) would be very helpful.   ;)
The good news is that it sounds like you were able to maintain a fairly steady RPM -- even if by hand.  KUDOS.
Cheers,   :)
Yada..
Omnibus
@Yadaraf,
I'm away from my rig right now but I'll do it in a bit. Your time is 3 hours earlier than mine so I hope at least it won't be in the wee hours at your place. Sorry about that.
Bruce_TPU
Evening All,
Quick update on a few things.  I picked up a box of SHCS 4-40  x3/4" for my Stators.  Identical to Al's.
Has anyone beside myself, wonder why Al would use SHCS screws, having to grind down each head, rather than a stainless steel flat head?  Splitting hairs again, perhaps, but one has to wonder why.  Tomorrow afternoon, I grind a few screw heads down.
I also picked up some packets of #4 stainless washers.  Identical to Al's.
I could not find any 4-40 nylon screws, only larger ones.  If anyone finds some online, please post.
I also received in my ABEC 7 Rotor bearings.  I will be testing both.
And of course my rotor did not arrive today.  Perhaps tomorrow.  It should be of the exact weight and size as Al's.
Now, about the Stewart-Warner Bearings.  My bearing guy heard back from them and it turns out that they do not manufacture the bearings, they only distribute them.  The people that Mike needed to speak with were in a meeting.  (of course.)  So Mike will contact them Monday and find out the Manufacturer of the bearings that they distribute.  Then he will contact that Manufacture and order said bearings.  A lot of work, but such is life.  I want a working machine, so will replicate as exactly as possible.   ;D
Cheers,
Bruce
vipond50
Quote from: Bruce_TPU on February 08, 2008, 10:13:29 PM
Evening All,
Cheers,
Bruce
Hi Bruce
Glad to here things are coming together for U. Now if u could check to see how magnetic your SS screws are before and after. Typically manufacture screws are heat treated included SS. With all my work with stainless i.e. 304, 304L, 308, 316 and 316L  grinding  or machining will make them more magnetic. So this being said, if Al ground or machined his 4-40 SC screw head height's they were magnetic to some degree. If a person want to reduce the magnetic effect then they will have to heat treated again. I do this by heating to a cherry red and quickly quenching them in cold water. They will take on a color of dark to black due to the oxidizing atmosphere (air). A true heat treat would be done in a controlled Atmosphere furnace.
Best Regards
Bill
Yadaraf
Quote from: Omnibus on February 08, 2008, 09:05:17 PM
@Yadaraf,
Omni,
Not a problem.  I bumped up the signal on your original audio and applied a ~100 Hz high pass filter.  It  helped slightly, but I amplified a lot of "noise" as well.  Can't really tell a lot.
Attached is an analysis of your latest audio, but don't read too much into it.
RE 3 hours must put you on the East coast.   :D
Cheers,   :)
Yada..
