Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 23 Guests are viewing this topic.
giantkiller
All of this information that I have mentally accumulated over my lifetime is racking my mind. These truly are mind blowing times we live in.
--giantkiller. Not enough time..
bourne
@ giantkiller
Do you mean that you also feel that the universe is speeding up and there is not enough time to take it all in.
Too much to learn, and seemingly, not enough time.
Yesterday I did some research on 'Technical Remote Viewing'
Some of the worlds best TRV practitioners seem to agree that the Earth will be affected by Large Solar Flares, within the next 10 years.
What if somebody were to TRV the TPU?
It has been done with the Bedini SG.
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
acerzw
@bourne
Cool... so what was the result of the TRV on the SSG? Not promising (I suspect) ?
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Localjoe
@Gk
i posted this in tesla resonance but you need it too .. I love when more connections are made.. church in england leads to ancient song through cymatics  ;D.. supports a432.. ah but more.. second document i find sheds light on somethig you should be interestin in for your freq testing.. finally a rhyme and reason to the phi spiral
The ratios of phi and the square
root of 2 are also responsible for the difference between the various tones in
the Octave, when measured as values of vibration in cycles per second. You
can take one note in the Octave and compare it to the note next to it, and the
two notes will always relate by one of these simple ?spiraling? ratios.
Therefore, we can now see that even though it seems strange at first, every
sound truly has a three-dimensional, geometric component. The same would
be true for every color.
heres the stuff http://www.foar.net/2007/05/rosslyn_chapel_motet_1.html  here's the clincher
3. Thomas and Stuart used this metal plate to recreate the ancient method of making notes. The plate is vibrated and sand poured on until it forms a particular pattern - indicating the correct pitch. The patterns match those carved into the arches of Rosslyn Chapel.
Basically we have calculated the frequencies of the 3 notes that the stave angel is pointing out and it amounts to this;
At (ancient tunings)
A = 432
B = 488
C = 512
1,432
How they did this
HOW THEY DID IT..
1 Carved angels and blocks above their head in arches of chapel baffled Thomas until he realised this one was holding a musical stave - and that the blocks signified notes.
2 Using this specially enhanced photo, Thomas and Stuart worked out that the carvings above the angel represent A, B and C.
3 Thomas and Stuart used this metal plate to recreate the ancient method of making notes. The plate is vibrated and sand poured on until it forms a particular pattern - indicating the correct pitch. The patterns match those carved into the arches of Rosslyn Chapel.
my take-
Something that should not be passed over is this.. A432 was ingraved in rock everywhere for a reason.. we will never get the results we want using the a440 scale of modern.  Even tho our major chords sound kind of pretty cause weve herd them taht way our whole lives .. theres many more overtones that become presesent when 432 is used.. find an old vesion of the Lycramosa i think its mozart and you'll get chills from the one with the choir in a 432 yet the newer versions when they change the pitch to 440 slandered sounds nice and eire but no chills...
EDIT:  More info sepearte source
So, Dr. Jenny?s research puts the final word in on the importance of the
geometric shapes in the sphere, in case we doubted their relation to the
Octaves of color (i.e. visible light) and sound. The ratios of phi and the square
be true for every color. Some people, including this author, have been able to
perceive this connection automatically in mystical states of consciousness,
without necessarily understanding the vision. Many people who have had
these visions send us email with great relief that they have finally understood
why they were seeing such formations in their mind?s eye
This was taken from a 6 meg pdf here it is http://www.thesonsofthelawofone.com/Resources/Shift%20Of%20The%20Ages%20by%20David%20.pdf   ;D
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
bourne
@ acerzw
The two results 'revealed' by TRVing J Bedinis Monster SSG in the past few days are;
1;  Magnet configuration. Super Super pole. Each magnet position comprising of 2 magnets with norths pushed together and souths facing axle/outwards. The scaler north that squirts out the sides combines with its neighbours field to trigger the coil (very fast 'on'). The 'real' south pole then assists the collapsing field of the coil (very fast 'off'). Sharper gradients! Sound familiar?
2; Earth rod connected to the Positive of the charging battery via a diode (battery draws aether from the Earth)
Very annoyingly, all my gear is packed away at the moment (moving house), so I can't try these suggestions out myself. I am itching to start again though.
I can tell your a tiny bit sceptical  ;) who wouldn't be?
But...
From what I have read about TRVing, (more than just Internet pages)
ANYONE
can learn how to do it!  ;D
It takes a lot of practice but think about the potential.  No more secrets. Time and space no longer a constraint.
You have one guess as to what I am going to start learning very soon?
