Does the safety of cold electricity depend on its frequency?
Started by emanresu, March 28, 2008, 12:02:15 AM
emanresu
Lindemann wasn't very clear about  what he means by frequencies above 100 microseconds being "completely safe to handle."
Vassilatos said that electrostatic waves with a frequency below 100 microseconds cause "pain and mechanical pressure." Surely none of the Bedini motors are generating waves at this speed, yet Bedini mentions using Aetheric energy for healing.
Q1: Is Bedini simply using the output of his motors as healing energy or is he using solid state devices to produce electrostatic waves above 100 microseconds?
Q2: If I touch ground and the output of the SSG with each hand will I suffer a heart attack?
PulsedPower
Muscles only respond to electrical signals to about 700hz above that the signal changes too fast and the muscle does not contract, that is for AC DC with superimposed AC will still have the dangerous DC potential. While frequencies over 700Hz are relatively safe from a muscular perpspective they can still do considerable thermal damage. you do not want part of your body cooked and this cooking procces can be vey deep. There will be medical standards to cover this, diathermy (RF body heating equipment) has been around over 70 years.
emanresu
Thanks, I need to read up on general safety so that I can use facts like these as a reference.
I guess it's more likely that he's taking the energy from the batteries. His statements in Energy from the Vacuum part 2 that the energy is a gas and that nature likes to operate at its own speed suggest that as long as it isn't being forced along a wire it probably won't generate a current.
magnetoelastic
OK people, let me repeat myself.
Electricity can be characterized by VOLTAGE, CURRENT, POWER and FREQUENCY.
Electricity does not have a 'temperature'.  It can be neither 'hot' nor 'cold'.
It is AMPERAGE through a resistance that determined POWER, and causes heating, which can be measured.
That said, the high-FREQUENCIES produced by a Tesla Coil can produce a visible corona discharge over a given length with much less POWER than at 60 Hz or DC.
The high frequencies produced by a Tesla coil do not penetrate the skin to the level of the nerves, so there is no usually no pain associated with encountering its low CURRENT arc.
Keep the FREQUENCY the same, but increase the CURRENT, and you will dissipate enough POWER in your skin to create a very painful RF burn, as you skin begins to cook!
amigo
Frequency is probably the most important factor because a human body is an active system in constant vibration. All living cells vibrate therefore operate on specific set of frequencies and regardless of you matching their exact frequency, or their harmonics, you are bound to step on a few "toes".
Further more all chemical elements have their own resonant frequencies (and harmonics) and some of those elements play major roles in the cellular (and below) bioelectrochemistry and could be affected by specific resonances.
So with all of the above considered, there so much that is overlooked when it comes to frequencies and vibrations in general of living things. An excellent reading to introduce you on this subject is Lakhovsky's book: Secret of Life, which is an engineers point of view on cellular processes in living organisms. I strongly recommend it to everyone because only upon reading it will you get (part of) the picture of what exactly is possible using various frequencies.
Incidentally, Lakhovsky is the fellow who created the MWO (Multiple Wave Oscillator) after realizing that diathermy only cooks the body and really does nothing to aid it.
Another reason everyone should look deeper into this subject is because all kinds of frequencies are around us all the time and most people can't even grasp the implications and effects they have on life on this planet.
