bob.diroto
Mannix/Steven Mark
Quote"By the way, have you seen the video of the compass turning violently in the center of the unit while in operation?"
Does anyone have a copy of this video or http address where I can find this video ?
Thanks in advance. Bob
bob.diroto
I'm now starting the process of trying to answer those probing questions that Steven Mark's posted at various points:
QuoteSteven Mark says:
Rotation of field. . . How many people think about that. If you could have a field that you could think of as a big ball. And you could rotate it in two directions what would the ramifications be?
I'm going to assume that by 'two direction' he means rotating the field left to right i.e. through a vertical axis and rotating the field top to bottom i.e. through a horizontal axis.
I did this by marking spots on a soccer ball so I know this is correct.
Any point on the surface of the 'big ball' will trace a spiral path around the ball going from top to bottom and then bottom to top and repeats. e.g. Like peeling an orange from top to bottom to get one long strip.
We already know that a working TPU in any one location will not work if turned upside down. The reason for this must be that the energy field we are tapping into must 'spiral' around the earth.
QuoteNorbert asks:
Now my question:  did you try your device already on the earth south site?
Steven Mark says:
YES NORBERT, WE DID TRY THEM SOUTH OF THE EQUATER,   THEY WORK IN REVERSE. CAN SOMEONE TELL ME WHY?
They work in reverse because if there is one spiral of energy that goes from top to bottom of the earth, if you are on the top of the earth looking down on the spiral, from your reference point, the spiral will go say clockwise, but if you are on the bottom of the earth the spiral, from your reference point will go anticlockwise. (Draw a spiral on a transparency to show that looking at a spiral from each side changes the direction of the spiral.) The very fact that the TPU must be turned over implies that the TPU 'receiving mechnism' must have a preset direction of rotation that doesn't initially reference the energy field.
Cheers ,Bob
bob.diroto
Quote from: tao on June 12, 2006, 10:10:34 PM
...If Earth had a strong enough magnetic field around her, one much stronger than what we have today, then these random lightning strikes would only be sending their respective waves in one direction, East."
Note that Steven places a that small magnet at right angles to the electrical ring(toroid) in his device as shown in the video...
The whole article was excellent. But more specifically I think Steven places the magnets above the locations where the kicks take place. If we believe the kicks are pseudo electrostatic then this would bias the charges to move in one rotational direction. Indeed if you look at the video of Steven placing the two magnets in the device that takes two permanent magnets you can see him take a magnet from a stack of magnets. He does this twice without flipping the magnets over before placing them in his unit. This means both magnets are place in the same orientation i.e. North both pointing in the same direction.
On another point that Tao mentioned about the battery.
I think there is no doubt that Steven uses a small battery to drive his control boxes. He specifically states that it took him time to learn how to use semiconductor circuits to control the frequencies. There is NO WAY you can have an operating *semi condictor* circuit without a reliable source of constant voltage. A small 9V battery would be sufficient.
YES THERE IS A ROTATING FEILD WHICH CAUSES ELECTRONS TO FLOW IN COPER WIRE AND BE USED TO PROVIDE USEFULL WORK FORSE. THERE ARE MANY WIRES  PERPINDICULAR TO THE MAIN COLECTOR.  THIS IS A NECESSARY PART OF THE DEVICE.
SINCERELY,
SM.
I really think we have cracked this.
The electrostatic field is made to initially rotate by the placement of the magnets.
The rotating electrostatic field creates a rotating magnetic field.
Further kicks make the electrostatic field bigger.
Making the magnetic field bigger.
As the rate of rotation starts to build the voltage gets bigger.
As the pulsing and rotation approaches a known resonant frequency to which the output coil is already tuned to by cutting down the length of the wire, the energy field that provides the 'kicks' starts to sync to the output coil.
The design problem Steven faced was that using auto-feedback to get the rotation going meant the unit naturally wants to run towards the resonant frequency. Alternatively he could generate the rotating field electronically at the desired frequency by using an inverter circuit OR by using a motor to spin some magnets and then have coils to pick up the appropriate sin wave. But these solution require bigger batteries something he had to avoid if he wanted to have a device that he could easily prove to be overunity.
At this point we don't need to worry about having a feedback mechanism working. Probably safer not to because if we directly control the input signal from completely an outside source we can reduce or turn off this signal if things start to get hairy.
At this point in the game, we can use outside power sources, sinewave/function generators, and high voltage pulse generators, in order to prove the concept.
Liberty
Has anyone tried to build one of these yet?
Liberty
"Converting Magnetic Force Into Motion"
Liberty Permanent Magnet Motor
gn0stik
Quote from: tao on June 13, 2006, 12:26:18 AM
Quote from: Liberty on June 12, 2006, 11:56:02 PM
I doubt it, because we are just forming the complete theory ;), at least I know I am doing this first.
It can't be that difficult to build, after all, look at Steven's first prototype in that video, :). It looks like he used some pieces from CD spindles, some copper wire, some bailing wire, and a magnet. And of course the control electronics, which can't be anything intricate.
The main problem was getting a complete grasp of the concept, and I now feel we have a fairly good grasp of it now, after piecing everything together from the videos, Steven's writings, and that last article I posted.
I agree, we are getting a handle on this. In the SM quote you posted along with the article.. this one:
QuoteI would also like to say that in the video Steven says "these devices take energy from the inherent magnetic field of the earth....there is a frequency pattern setup in here...if you hold the device in your hands it vibrates ever so slightly right around at 7.3 cycles per second".
I wonder if he meant 7.83, which is the strongest of the schumann resonances.
If so, that is a big indicator as well.
I sure would like some confirmations of our ideas, if we're going in the right directions or not.
