The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
Cap-Z-ro
ltseung888
Please read about the Russian Inventors Conference (11th Moscow International Salon of Industrial Property "Archimedes") in
http://eng.archimedes.ru/
In the period from April, 1 to April, 4th, 2008 in Moscow on the territory of the cultural-exhibition center "Sokolniki", pavilions 2, 3.1, there will be held the 11th Moscow international Salon of Industrial Property "Archimedes".
I sent the Lee-Tseung theory information to the organizers earlier.  I believe this is an important group in Russia that will develop many Over Unity or New Energy Inventions.  That is little doubt in my mind that they have many scientists who can understand the ?O-level Physics? material as presented.
The World will benefit with our sharing of information.
Devil
Quote from: ltseung888 on April 06, 2008, 04:50:45 PM
Tseung, do you know that your use of the phrase ?O-level Physics? is extremely insulting to the existing scientific ?establishment?.  It implies that they were lazy and never did a proper Force, Work and Energy Analysis of the Pendulum.  The pendulum has been taught as an example of simple harmonic motion for centuries.
Simple harmonic motion - Wikipedia, the free encyclopedia
Mass on a pendulum: In the small-angle approximation, the motion of a pendulum is approximated by simple harmonic motion. The period of a mass attached to a ...en.wikipedia.org/wiki/Simple_harmonic_motion ?
You even boldly said that they incorrectly applied the Law of Conservation of Energy in not taking the lead out energy into account.  You basically said that the patent offices of the World were wrong.  They wrongly rejected many inventions ? classifying them as impossible perpetual motion machines.  Do not underestimate how many enemies you have created with such statements.
This amounts to a frontal attack by you on the ?establishment?.  There will be inevitable jeers.  None of the scientists can find fault with your mathematics and physics.  But they will attack your personality, your credibility, etc.  Are you ready to take on such an assault?
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
ltseung888
Here I would like to display the "no-battery" loudspeaker as brought up by Hans.
The "no-battery" loudspeaker is a good example of leading out magnetic or electron motion energy via pulsed vibrations.  The working products were used in the 1930-50 period.  We do not need to think of or design a demostration prototype.
The physics and mathematics cannot be wrong.  The "no-battery" loudspeaker cannot be wrong.
Top Gun
Mr. Tseung,
I would like to expand on your quoting the no-battery loudspeaker more.  Hans has a thread in:
http://www.overunity.com/index.php/topic,4172.0.html.  His comment on Mr. Tseung using the Lee-Tseung theory to explain the loudspeaker is:
A detector circuit picks up an amplitude modulated wave. The germanium diode acts as a half wave rectifier stripping off half of the signal. The remainder is half a carrier wave that shows the signal as a series of peaks depending on the frequency, quality and amplitude of the acoustic signal. The loudspeaker or headphone is too sluggish to reproduce the carrier wave and therefore the audio signal is all that remains.
The audio signal is RANDOM as far as frequency or amplitude is concerned in technical terms, though musicians would get kind of miffed if you described their work as random noises artfully assembled into a harmonious whole, yet technically this is what it is.
If you were to apply Lee-Tseung Pulls as a signal source all you would hear is the noise of a jackhammer in various frequencies.
My comments are:
(1)   The half wave signals act as Lee-Tseung Pulls.  These half wave signals have a carrier signal with the acoustic signals superimposed on top.
(2)   The half wave signals come in via Coil A and caused the soft iron reed B to vibrate.
(3)   The soft iron reed B is subjected to the very strong magnetic field from the Horseshoe Magnet E and Pole Shoes F.  This arrangement is analogous to the pendulum in a strong gravitational field.
(4)   Magnetic Energy (or Electron Motion Energy) is Lead Out.  The amplitude of vibration greatly increases and is transmitted via the Spring Steel G and the Connecting Rod C to the Paper Cone D.
(5)   Much of the Lead Out energy is transformed into mechanical energy in vibrating the membrane of the Paper Cone D.  The membrane is too sluggish to reproduce the carrier wave and therefore the audio signal is all that remains
This detailed explanation should tie the Lee-Tseung theory with the no-battery loudspeaker much better.
